Does the Volvo "in the mirror" antenna mount typically have a good ground?
Discussion in 'CB Radio Forum' started by Pmracing, Mar 27, 2013.
  1. Pmracing
    Pmracing Road Train Member
    6,354
    3,178
    Jan 28, 2011
    Arlington Heights, IL
    I have a company 2010 volvo with the antenna mount in the mirror. Does that type mount typically have a good ground?
    How do I test how good it is?
    Thanks,
    Mikeeee
  3. Drifter42
    Drifter42 Hopper Heartache
    2,141
    3,838
    Dec 4, 2011
    Seymour IN
    Get an swr meter to check it. Best bet on a volvo is to get what they call a bird perch mount. Take out the top screw on your mirror mount and screw in the bird perch in that hole, then put the antenna mounting bracket on the perch. Thats the best and most inexpensive way to get the best ground on a Volvo. Perch mount costs about 10 bucks in the truckstop. It's a stainless steel rod about 5 or 6 inches long with threads on one end to screw into mirror mount screw hole.
    Pmracing Thanks this.
  4. Pmracing
    6,354
    3,178
    Jan 28, 2011
    So if it has a good SWR that means it has an adequate ground?
    Mikeeee
  5. 6string
    6string Bobtail Member
    49
    13
    Mar 24, 2013
    yes swr means standing wave ratio if its over 1.5 -1.8 then its mostly ground problem unless ur 3.5 then mostly its coax you gotta have a good swr and ground will help on that
  6. Drifter42
    2,141
    3,838
    Dec 4, 2011
    Seymour IN
    Yes the lower the swr's, the better the ground.
  7. Pmracing
    6,354
    3,178
    Jan 28, 2011
    Apparently there was something wrong with the RF gain pot. The shop (I'm guessing here) Oiled it and blew some crud out and it receiving seems much more powerful. But all speech I hear is crackly.
    I looked into using a perch mount, but I don't think it is possible with my mirror support configuration. I will take a photo of the mounting issue and post it, after I get back to the truck.
    Mikeeee
  8. Pmracing
    6,354
    3,178
    Jan 28, 2011
    That is my dilema. I do not want to start chopping the whip in search of a good SWR if a bad ground is the problem.
    Mikeeee
  9. 6string
    49
    13
    Mar 24, 2013
    rf pots do not have nething on them from factory and shouldnt ever have solder joints checkd on it bad recieve is ur antenna .your antenna makes up 90 percent of your system no one said chop it but sometimes you have to clip a 1/4 of it check this out for more info
    http://cbradiomagazine.com/April 2007/SWR.htm
  10. MsJamie
    MsJamie Road Train Member
    Nope. It's quite possible that an antenna with a good ground will have a higher SWR than one with a poor ground. A 50Ω resistor will have a 1:1 SWR and no ground at all.
    A resonant 1/4 wave antenna on a perfect ground has an impedance of 37Ω, which is a 1.5:1 SWR. Add a dozen ohms of ground loss, and it'll show a 1:1 SWR, but be less efficient.
  11. 6string
    49
    13
    Mar 24, 2013
    you just have to play with ur location and grounding but of all the times ive used radio ive yet to have a groundloss or a swr of 1.1 and have bad recieve i have always tuned mine by grounding and swr of 1.1 and recieve up to 15 miles without skip on a clear night just my opinion a good extrnal meter doesnt lie
