does this make sense?
Discussion in 'Questions To Truckers From The General Public' started by Meltom, Apr 20, 2011.
  1. Meltom
    Meltom Road Train Member
    5,423
    3,019
    Jan 24, 2011
  3. 48Packard
    48Packard Ol' Two-stop Shag!
    8,364
    9,933
    Apr 19, 2009
    Could be anywhere
    Everybody has their own little twists to it, but in a nutshell, it's pretty much right-on to me.
    I use the same numbers when I'm guesstimating ETDs and ETAs, only depending upon the route, I may even use 40mph for a portion of the route to be on the safe side (for example, pulling a heavy load out of rural PA, WV, or other such hilly area...weather conditions play into that as well).
    But the slides keep it simple...you don't want to bog down newbies with every conceivable issue, because you can't, and the slides don't.
    Meltom Thanks this.
  4. Biscuit75
    Biscuit75 Road Train Member
    Seems like a pretty good explanation to me. That's how I learned, but without the fancy computer slide show. I usually take my driving time, add 10 hour break, then add 2 hours per day for each day of the trip (if it's a long trip) for bathroom break, fuel stop, lunch, etc. If you can read a map you should be able to figure out where you're going to stop for the night and then use reference materials to find a place to stay.
    Meltom Thanks this.
  5. Meltom
    5,423
    3,019
    Jan 24, 2011
    Thanks for the feedback. I'm hoping to be able to apply this in the near future. If you have any suggestions let me know.
  6. libertasvelnex
    libertasvelnex Bobtail Member
    47
    19
    Dec 30, 2010
    Simplest way I've found is to assume 10 mph below posted limits (or governor limits), and assume a 12 hour day (leaving an hour for breaks). It usually gets me there early, so I always have a buffer.
    Meltom Thanks this.
  7. blanks
    blanks Light Load Member
    134
    16
    Apr 12, 2011
    Chatham, ON
    It's called Microsoft trips and streets, how do u know your routing doesn't take you down nightmare on Elm street, u don't till u get there, unless your me and you already been there, twice.
    Meltom Thanks this.
