Does ULSD clog up your cummins N-14
Discussion in 'Trucks [ Eighteen Wheelers ]' started by pktruckdriver, Nov 1, 2007.
  1. pktruckdriver
    pktruckdriver Bobtail Member
    25
    5
    Jan 4, 2007
    Fuel milage went from 6.5- 7.5 2yrs ago to about 4.9-5.4 now and can not find out why??
    Checked everything out, even the computer, no bad sensors, no clogs in lines , no bad injectors, everything looks good, but fuel milage is CRAP
    WHY WHY WHY
  3. 24valve puller
    24valve puller Medium Load Member
    399
    89
    Sep 8, 2007
    N.E. Oh
    its the fuel, but have you checkes for boost leaks like a bad charge air, or bad boot. Does the boost seem as high as it always was?
  4. Burky
    Burky Road Train Member
    I have to admit, if there was no problems with the fuel, I would be looking elsewhere, and the charge air cooler would be the first place I would be looking at. A leak there woud do it and it's so gradual you would never know it. And you can't tell just by looking, since there is no load and no real amount of boost while sitting still.
    You haven't been in to Cummins at any time in that time frame and allowed them to reset the computer for emissions purposes, have you? They have a tendency to "update" and it can cause a drop off in mileage traceable to the improved emissions.
    If everything else in the engine is good, then I would get hold of the boys at Pittsburgh Diesel and have them check out the engine. If it's happened to a Cummins, they have probably seen it before.
  5. steved
    steved Bobtail Member
    28
    There is a slight decrease in available BTUs from ULSD, but you really shouldn't notice it.
    Have you checked the airfilter? Did you blow back through the fuel lines into the tank (plugged pickup?)?? Checked the exhaust for pinches/restrictions (such as a internally-failed muffler)? And just because a sensor "reads" good, it might be on the "low" side of its optimum range.
    I'm not sure the older engines are capable of the injections pressure the newer "common rail" trucks are producing...and that might be the difference.
    I saw an improvement running ULSD in my pickup, but it was designed to run the ULSD.
    ULSD will "scrub" the fuel system, it will mobilize things that were floating around the system.
    steved
