Does your dispatch still use a map?
Discussion in 'Motor Carrier Questions - The Inside Scoop' started by Nothereoften, Oct 6, 2018.
  1. Nothereoften
    Nothereoften Light Load Member
    261
    265
    Oct 6, 2018
  3. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    Third choice is neither he thinks a couple finger widths on map is a few hours till you tell him it’s 500 miles
  4. Tolmie
    Tolmie Medium Load Member
    362
    256
    Dec 22, 2017
    They use pc miler and whatever the computer say. I don’t think they even look at the map.
  5. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,137
    Mar 5, 2016
    White County, Arkansas
    It's two inches apart on the wall map. You should be able to do that. Half of our drivers do.
    HA.
  6. skellr
    skellr Road Train Member
    8,737
    12,187
    Jul 17, 2011
    The Village, Portmeirion
    Not sure what you mean? "Dispatch" is a usually a separate entity and often disconnected with reality.
  7. REO6205
    REO6205 Road Train Member
    13,171
    60,501
    Feb 15, 2014
    California.
    We use both. It can be done.
  8. Nothereoften
    261
    265
    Oct 6, 2018
    Where do you work? Obviously not the same place as me
  9. Nothereoften
    261
    265
    Oct 6, 2018
    That was my early 2000's dispatch. Now the use Google and car routes. "It's only (insert mileage)" my reply"with a multi thousand dollar fine that way"
    magoo68 Thanks this.
  10. moloko
    moloko Road Train Member
    1,569
    1,376
    Oct 26, 2012
    seattle, wa
    They calculate the route as though you are driving a class C car at 86MPH on the freeway. "The computer says it only takes 3 hours to go from Phoenix to L.A. so you should be good with the hours you have left."
  11. Nothereoften
    261
    265
    Oct 6, 2018
    With Max weight permit and an oversized route. Actually when that was the case my dispatcher had a clue
