Don’t try this at home
Discussion in 'Experienced Truckers' Advice' started by Cat sdp, Dec 12, 2019.
  1. Truckers Report Jobs
  2. Dennixx
    Dennixx Road Train Member
    4,534
    14,555
    Feb 13, 2010
    twin cities
    Water injection?
    Hope it's a company truck...lol
    FlaSwampRat and singlescrewshaker Thank this.
  3. Cat sdp
    Cat sdp . .
    21,196
    75,208
    Apr 8, 2012
    Orion's Belt
    Hydrogen fuel cell power maybe......
  4. Cattleman84
    Cattleman84 Road Train Member
    9,996
    71,337
    Nov 1, 2017
    The Sticks, Idaho
    Well as long as he goes slow and the water dont get much higher the air intake should be above water... But as we see in the video a good amount of water is still sloshing into the intake, because its coming out the stack... Id bet he didnt make it much farther... And probably trashed the engine... SMDH
  5. Moosetek13
    Moosetek13 Road Train Member
    14,833
    18,725
    Nov 1, 2010
    Burnsville, MN
    I used water injection in one of my cars, back in the day.
    Very cool concept that was used in WW-2.
    Water mixed with methanol was injected into the fuel mixture to increase power for short periods, such as take off or steep climbing, dogfights...
    My dad told me about it, so I tried it.
    I could advance the timing a few degrees more and adjust for a richer fuel mixture in full throttle conditions with it.
  6. MYSTYKRACER
    MYSTYKRACER Medium Load Member
    432
    611
    May 30, 2019
    Yes, it's essentially chemical intercooling used to ward of detonation in forced induction engines and where heat can cause detonation in high compression n/a engines.
    I have an AEM water/meth injection kit on my ecoboost F150 ( 3.5l twin turbo ).
    FlaSwampRat Thanks this.
  7. MYSTYKRACER
    432
    611
    May 30, 2019
    Houston, TX FTW! Not to far from where I live actually.
    I'd guess this was during hurricane Harvey but this kind of surface street flooding is annoyingly common during any heavy rain event.
  8. Moosetek13
    14,833
    18,725
    Nov 1, 2010
    Burnsville, MN
    Yup.
    The water cools things, but the methanol burns to give some added heat and power.
    All is good until you get into an accident with the system turned on, and then you get the chambers filled with it.
    Total lock up. Nothing moves, and a lot of damage.
    I got T-boned from a drunk racing through a red light.
  9. Puppage
    Puppage Road Train Member
    4,266
    7,381
    Aug 2, 2012
    Connecticut
    It’s a drive thru truck wash.
  10. TripleSix
    132,547
    Downtown Houston is fascinating. The interstates and state highways were built way up in the air, not steep and banked like around Dallas. If you’ve only been there by truck, odds are you will never see how far down the ground is in certain spots. And there’s bridge on top of bridge on top of bridge. A hard rain, that water has nowhere to go. Some of those roads near the bottom will have flood lines 30 feet deep.
    You must live on the west side.
