Don't crank down landing gear all the way !! Please !!
Discussion in 'Experienced Truckers' Advice' started by WisconsinF150, Mar 19, 2016.
  1. WisconsinF150
    WisconsinF150 Light Load Member
    297
    213
    Dec 21, 2014
    Don't be the Driver who cranks the landing gear all the way to the ground. Leave an inch between the ground and the landing gear plate.
    That way the landing gear doesn't bind if you pull out crooked or the next driver isn't lined up perfectly.
    Another reason is that someone may park another trailer so close that you can't get between the trailers to crank up your landing gear.... If there's an inch of space under your landing gear, you can pull the trailer out far enough to access the landing gear arm and be able to crank it up.
  3. cnsper
    cnsper Road Train Member
    5,869
    27,421
    Feb 28, 2014
    Won't help you if I drop one.... You with low pro 22.5s and me with tall 24.5 tires... LOL
    Jazzy J, flood, roshea and 7 others Thank this.
  4. truckthatpassesyouby
    truckthatpassesyouby Road Train Member
    1,876
    6,124
    Jun 3, 2015
  5. Riprap
    Riprap Light Load Member
    286
    1,979
    May 31, 2014
    Saginaw, MI
    I appreciate those who crank landing gear all the way down, we have overly lazy drivers at our company who wont crank them down to the point that I have had to use blocking on frame rails and use my tractor airbags to get the trailer raised high enough before I can back under them. It makes me not happy.
  6. ajohnson
    ajohnson Medium Load Member
    580
    1,368
    Jan 6, 2016
    chicago area
    Why can't you crank it up the rest of the way?
    unloader and joesmoothdog Thank this.
  7. CJndaTruck
    CJndaTruck Road Train Member
    3,348
    3,364
    Nov 21, 2014
    Knoxville, TN (area)
    How about we just drop trailers? You ask the impossible. When you go to drop a trailer you often set your brakes. Ie dump your bags. Sounds like you don't like to crank? Maybe you are new?
    I just deleted a lot. I wish you the best in this endeavor
    spyder7723, Lonesome, unloader and 2 others Thank this.
  8. STexan
    STexan Road Train Member
    14,963
    29,154
    Oct 3, 2011
    Longview, TX
    This is and always will be a bone of contention for all drivers, for all time. But the OP drop method seems to be the most unappreciated by a majority of drivers based on my readings and experiences. I'm not going to post my normal response to this post that comes up several times a year. I'm glad I work at a place where most drivers seem to know the optimal procedure, that works best for both parties, and this 'aint it
  9. joesmoothdog
    joesmoothdog Heavy Load Member
    737
    1,144
    Aug 5, 2013
    OTR
    Wowsers. Are we a'b itc hin about picking up an mt or a spot load? GOAL applies btw. SMH.
  10. tinytim
    tinytim Road Train Member
    5,143
    18,233
    Oct 29, 2007
    Northern Ontario
    Too high beats too low.
    Picked one up today that was so low I couldn't even get the frame rails under it without dumping the air. Had the choice of cranking up a loaded trailer or destroying tires.
    If all trucks had the same size tires and same 5th wheel height life would be easier but that's not the case.
    If you have big tires and a high 5th like me leave the inch or more. If you're at the opposite end of things crank it a bit more.
  11. Zeviander
    Zeviander Road Train Member
    4,887
    36,995
    Jan 23, 2015
    Winnipeg, MB, CA
    I leave an inch all the time. My company runs mostly 22.5s on their trucks, but us regional guys tend to have 24.5s, so if we drop them flat, the 22 guys have to crank the trailer down to hookup properly.
    When in doubt... Get Out And Look. Seriously.
    JReding, EZ Money, Dominick253 and 2 others Thank this.
