Don't Kill Yourself Repairing Company Equipment.
Discussion in 'Experienced Truckers' Advice' started by LetsGoBrandon$, May 26, 2023.
  1. LetsGoBrandon$
    LetsGoBrandon$ Bobtail Member
    34
    51
    Oct 15, 2021
    I go to a shipper to pick up a preloaded company trailer and it didn't have auto inflation system on the trailer wheels. I noticed that one of the tires was unseated. I called maintenance and they said they can't get anyone out until in the morning. I said f* it I will fix it myself. I pull the trailer up onto a couple boards and got the bad tire up in the air. I put two two inch ratchet straps around the tire and got them snugged down enough to get the tire seated with a little air. I take the straps off and locate a nail sized hole on top of tire. I plug the tire with tire plug and rubber cement. I proceed to put air into the tire like normal.
    BOOM
    The inside wall of the tire exploded. I'm guessing the rim might have wore a spot on it or maybe this cheap ##* company should stop using these retread tires. You can't tell me that a sidewall on a tire should last 100,000 miles.
    That brings me to my next question.
    WHY CAN'T SOMEONE DEVELOP A SOLID RUBBER TIRE FOR SEMI TRAILERS???
  3. Moosetek13
    Moosetek13 Road Train Member
    14,878
    18,810
    Nov 1, 2010
    Burnsville, MN
    So with all that work you are back to where you were at the beginning.
    Waiting for a repair.
  4. Chinatown
    Chinatown Road Train Member
    77,342
    181,356
    Aug 28, 2011
    Henderson, NV & Orient
    Unless it was a real heavy load, I would have ignored it and hit the road.
  5. LetsGoBrandon$
    34
    51
    Oct 15, 2021
    Yep. I actually managed to get the tire reseated though. It was just a crappy tire. Sidewall gave out around 60 or 70 ish psi.
  6. LetsGoBrandon$
    34
    51
    Oct 15, 2021
    48,000 pounds
    Albertaflatbed, The_vett and Chinatown Thank this.
  7. lester
    2,941
    7,977
    Jan 2, 2012
    NW, Iowa
    A solid rubber tire would ride like crap and be heavy as heck
  8. Big Road Skateboard
    6,813
    38,383
    May 2, 2021
    It blew because it was damaged from being ran flat. Happens all the time.
  9. cuzzin it
    cuzzin it Road Train Member
    3,639
    11,887
    Jan 19, 2008
    Berea, KY
    Thats why tire shops want to replace tires that been run flat
  10. Big Road Skateboard
    6,813
    38,383
    May 2, 2021
    Yep. Some customers would get mad because we wouldn't just air up a tire that had been flat. We would fix flats, but we're dismounting first and checking thr sidewall inside
  11. LetsGoBrandon$
    34
    51
    Oct 15, 2021
    Would it ride like crap though? If you only have them on the trailer and keep your air tires on the tractor. I would think you wouldn't notice it in the cab.
    Stringb8n and The_vett Thank this.
