DOT Age Requirements Interstate Commerce
Discussion in 'Trucking Industry Regulations' started by CaryD, May 9, 2014.
  1. CaryD
    CaryD Bobtail Member
    14
    8
    Mar 5, 2013
    Wichita Falls, Texas
    Here is the scenario.
    Driver is age 19
    Moving a load 45 miles from Wichita Falls, Texas to Lawton, Oklahoma
    Vehicle is under the weight limit required to have a CDL to operate (Class C license only required)
    Load is interstate commerce according to government bill of lading. (household goods originating outside of state, delivered outside of state)
    Question: Is it legal to allow this driver to operate, or must the driver to be 21?
    There is a little confusion/debate going on internally here and I could use some clarification.
  3. pattyj
    pattyj Road Train Member
    22,474
    20,137
    Jul 19, 2008
    Sioux City,ia
    Good question,I think any class A cdl holder operating out of state has to be 21 and intrastate is 18.
    CaryD Thanks this.
  4. Meltom
    Meltom Road Train Member
    5,423
    3,019
    Jan 24, 2011
    CaryD Thanks this.
  5. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    383.5 Definition of a CMV:
    A CMV is the kicker here. Just because it might be tagged a commercial vehicle by state requirements doesn't make it a CMV under FMCSA standards. If it's 26,000 lbs or under then he is okay.
    pattyj, CaryD and Meltom Thank this.
  6. stayinback
    stayinback Road Train Member
    3,911
    8,256
    Jan 24, 2014
    chicago,il
    Ahh...In the Limelight 21 is the answer.......Dont make a lotta noise with this and he'll be just fine,
  7. 70s_driver
    70s_driver Medium Load Member
    611
    358
    May 4, 2014
    You might check this out for the info you need? Im not sure myself? http://www.fmcsa.dot.gov/registration/commercial-drivers-license/drivers
  8. 70s_driver
    611
    358
    May 4, 2014
    Might be a good idea to call your state licensing agency and tell them what you are doing and ask them? according to the FMCSA if the class c vehicle does not haul passengers and does not haul hazmat, its not regulated by them but I could be misinterpreting it? Id call the license bureau or the D.O.T Enforcement office in your area?
    CaryD Thanks this.
  9. Roadmedic
    Roadmedic Road Train Member
    18,951
    8,981
    Apr 4, 2007
    When crossing state lines, the fmcsa applies to all commercial motor vehicles. As stated before, the definition of a commercial motor vehicle is any vehicle with a gross vehicle weight rating of 10,001 lbs.
    You have to be 21. The exception is when it is agricultural related.
  10. CaryD
    14
    8
    Mar 5, 2013
    So a Ford F250 Van rated at 8500 pounds is expempt, and the driver need not be 21?
  11. Roadmedic
    18,951
    8,981
    Apr 4, 2007
    That is correct. However, if it connects to a trailer, then the two gvwr's are added together.
    Meltom Thanks this.
