I'm confused.
I have an opportunity to run some cargo across state lines. I'm going to use a rented 24' Box Non CDL. I called FMSCA to explain this to them, asked if I would use the rental truck companies DOT and MC numbers or do I have to get my own under my business name. FMSCA told me I had to get my own. I called the rental agency and asked them this: "If I rent a commercial vehicle from you can I cross state lines to make deliveries? and do you have the DOT and MC numbers in order for me to do this?" ,, He stated I can cross state lines with their trucks.
I called the FMCSA back and told them what I was told. Told them I need to know 100% if what the rental agency told me is true because you previously told me I need those numbers and i don't want to cross state lines and have a problem. He took my name and number and said he'd call me back. It's been 3 hours now.
Anyone know the correct answer? I'm needing the answer because while I sit here typing it's costing me lost time on the road.
DOT, MC Confusion
Discussion in 'Questions From New Drivers' started by Independent51, Jan 5, 2012.
Try the OOIDA website. You will find everything you need to know on there and if not they will have a link to someone that can help you obtain all the proper permits and what-nots.
Independent51 Thanks this. -
http://www.fmcsa.dot.gov/
javascriptopupwin('/registration-licensing/gettingstarted/guide0.10.htm')
Try the second link first. It's a fill in the blank questionnaire on what/where you are going to haul and then it tells which hoops you need to jump through. I do know that if you cross state lines with more than 10,000 pounds you are engaging in interstate carrier work. Needing or not needing a CDL is a separate issue from whether or not you will need a DOT # and some type of authority.Independent51 Thanks this. -
Since the rental agency is renting you a "non CDL" truck, then you are good to go across state lines, that is if you are a private citizen renting this truck to move your own furnishings, however, once you start doing a commercial enterprise, such as interstate commerce, you'll need your own numbers etc.
wis bang, jbatmick and Independent51 Thank this. -
Yup. You guys are good!
You need a USDOT number if:
- You are going to be working for yourself (NOT leased onto another company)
- You are operating interstate (crossing state lines). If you are never leaving your home state, check with your home state for rules and regulations.
- Regardless of whether you are hauling "for hire" or "not for hire". So, if you need an MC number, then you must get a USDOT number, but not vice versa.
- You will be hauling "for hire." This means you will be hauling other peoples goods. If you are only hauling your own company's goods, you do not need an operating authority.
I would strongly suggest that you do not get your MC number until you have insurance lined up, or at least gotten real quotes. You will have a certain amount of time to get all paper work in order once you get your USDOT/MC number otherwise they will deactivate you. Once you are deactivated it's an $80 charge to re-activate. It also involves more paperwork that cannot be done online. -
Now I have a question.......with this rental box truck is he required to stop at the scales if he passes them on his trip? I have a reason why Im asking this, just would like to get the input of a few drivers on here. I guess what Im asking, what trucks must stop and the scales which ones are exempt?
P S 51 you better get on the road, you already killed 4 hours waiting on the answer!! lol -
You can be either a common carrier or a contract carrier. Better look up the real difference but the short version is being a contract carrier is cheaper insurance wise. It's basically if you negotiate rates you are "contract", if you publish rates you are "common"
Well even if he is not conducting interstate commerce, here in TN he must enter the scales......here is TN's stance on this issue: "Tennessee weigh masters say that all trucks must enter weigh stations- including rental trucks on chassis larger than the pickup truck chassis" I know, beacuse I lost a $50 bet to my neighbor, who just moved here form FL. He said it is required in Florida as well............before he bet me, he failed to mention his father-in-law works for the Commercial Vehicle Enforcement in FL. I even went down to the deparment of safety to verify, it seems to me it would just be for any larger truck conducting business for hire, not someone moving their own items........not so according to the enforcment.
More info.
Here is the lowdown on log books.
First of all if your GVWR/GCWR is under 10,001 lbs., you are free to drive as much as you want without stopping and without logging.
If you are returning to your home terminal every day and you are not traveling more than 150 nautical miles (1 nautical mile is 1.15 miles) then you do not need to keep a log book, but you do need to keep a "RODS" (Record of Duty Status).
If you are over 26,000 lbs, this changes from 150 nautical miles to 100 nautical miles.
If you are driving "over the road", i.e. you will not be returning to your home terminal, you must carry an official HOS log book and fill it out every time your status changes.
Regardless of whether or not you are returning to the home terminal, you have to follow the "Hours of Service" regulations.
You must be able to show a 7 day history.
Pre and Post trip inspection of your vehicle every day. Keep copy in the truck and another copy at terminal. A lot of HOS log books will also have a daily vehicle inspection log in the same thing. This is basically going over your truck to make sure everything works-- lights, brakes, couplers, horn, etc.
"Bill of Lading" form filled out, with you, in the truck, for anything that you are hauling (that is not yours?).
You need to create a file for yourself and have it readily available on file at your home terminal. While this seems a little absurd because "I know my own work and driving history" you need to have it in written form for when you get audited by the DOT.
