DOT Physical Exam
Discussion in 'Questions From New Drivers' started by Pudz1703, Jul 14, 2012.
  1. Pudz1703
    Pudz1703 Bobtail Member
    17
    Jul 14, 2012
    Georgia
    I have been seeing a lot of different feedback online and i wanted to get input from the pros on here...
    My question is, during the DOT physical exam, they test your hearing...problem is, i have unilateral hearing, which means i am 100% deaf in my LEFT ear,m and have been since birth..but i have 100%hearing in my RIGHT ear...will i pass the DOT physical exam?
    Any help is really appreciated! i need to know this before i get my hopes up of joining my CDL school.
  3. jbatmick
    jbatmick Road Train Member
    2,197
    2,499
    Dec 1, 2009
    hastings, Fl
    I have never had my hearing tested by machine. The doc always justs lowers his voice a little, uses his hand to hide his mouth, and says something. If I can hear it, it is OK. Some carriers probably are more thorough. The rules say you must hear a forced whisper at 5 feet,then it goes on to list the requirememnts if you use a machine. Hearing aids are OK.
    If you are totally deaf in one ear, I would be surprised if you passed the physical, but you can apply for an exemption, or waiver. Good luck.
  4. Houndstooth
    Houndstooth Light Load Member
    55
    6
    Jun 12, 2012
    Phenix City, Al.
    Depends on where you get your physical, im not telling you to lie but there not ganna have your personal medical records to look at. You might....you may not. If it was a Werner physical you would pass. Do you have good enough hearing that you wouldnt put lives in danger? Be truthfull with yourself before you answer. Good luck to you!
  5. starsonwindow
    starsonwindow Medium Load Member
    569
    165
    Feb 2, 2012
    Phoenix, Arizona
    Well Partner Welcome to the Forum, I am not a MD but the test is simple and since this has been this way since birth you have learned to adapt to it, what they have done in both of my DOT Phys. is they step away from me in the exam room and turn their head and whisper at a very high audible level and say a word for example "Hello" and then they get on the other side of me and say another word for example "Good Bye" and you repeat it back again, it is pretty dang easy. I don't know you can check wioth the school and see what they say. I hope this helps.
  6. Pudz1703
    17
    Jul 14, 2012
    Georgia
    I've been deaf since birth, so yes, my hearing in my right ear makes up for the loss in my left..i have absouletely tremendous hearing in my right ear....sometimes i honestly forget i am deaf in my left ear since i hear clear as day with just my right ear. i can easily hear a forced whisper in a room though if that was the case with a doctor.
  7. jbatmick
    2,197
    2,499
    Dec 1, 2009
    hastings, Fl
    You can Google a DOT form, and it gives some parameters.
  8. Houndstooth
    55
    6
    Jun 12, 2012
    Phenix City, Al.
    You should be alright then....all you can do is try.
    Pudz1703 Thanks this.
  9. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    http://www.fmcsa.dot.gov/rules-regulations/administration/fmcsr/fmcsrruletext.aspx?reg=391.41
    Your's is a strange situation because they assume both ears work or don't work. All I've read refers to minimums in the better ear. But I did read one part about minimums in the worse ear.
    Are you able to improve the bad ear with a hearing aid?
    Here are some reads....
    Page 24 about halfway down
    http://ntl.bts.gov/lib/30000/30400/30459/Hearing_DOT-FMCSA_-_FINAL_8-29-08.pdf
    Medical Examiners Certificate with instructions for the examiner. A little past halfway on the scroll bar.
    http://www.fmcsa.dot.gov/documents/safetyprograms/Medical-Report.pdf
    You can go here and dig some more and even email them.
    http://www.fmcsa.dot.gov/rules-regulations/topics/medical/medical.htm
    I think you should be able to. This sounds like one of them things one doctor might approve and the next doctor might not. It all depends how they interpret things.
    Good luck!
  10. Pudz1703
    17
    Jul 14, 2012
    Georgia
    I hope i am able to, i've read these rules over and over, and it sounds to me like, if i am able to hear from my better ear, which is my right ear, i should be able to pass the hearing section with no problem...and No, the left ear is a non fixable ear, no hearing aids or anything will help it.
  11. Pudz1703
    17
    Jul 14, 2012
    Georgia
    So from what i have read, i should be ok even if i only have use of one ear...i think im reading all the rules and regulations correctly.
