DOT Physical Question
Discussion in 'Questions From New Drivers' started by wfutch79, May 11, 2017.
  1. wfutch79
    wfutch79 Medium Load Member
    313
    454
    Jul 1, 2013
    St. Petersburg, Florida
    A DOT Physical is the same no matter what state you may get it done in, correct? As an example I can get a physical in Georgia and get my license in my home state of Florida and it will not be a problem?
    Reason I ask is because I am behind the 8-Ball to get everything done to register for school to start on May 22nd and I am headed to Georgia for a few days to celebrate my great-grandmother turning 100. Figured I could slip away while up there and knock out a physical to cross that off my list.
    On another note, if you are traveling between Tampa and Warner Robins Georgia on I75 tomorrow stay clear of the 30 foot Cruise America RV .... :biggrin_2559:
    passingthru69 and SHOJim Thank this.
  3. dptrucker
    dptrucker Road Train Member
    4,681
    3,197
    May 14, 2012
    adelanto,ca.
    Call the school and see if they will accept that physical.
    wfutch79 Thanks this.
  4. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,135
    Mar 5, 2016
    White County, Arkansas
    You need to know two things with a DOT physical.
    Say NO until the doctor runs out of questions prefaced with do you have...
    Do not volunteer information. If the doctor does not detect a problem checking you, it is likely not a problem. Unless you make it one.
    ethos, BigTennOTR, G13Tomcat and 6 others Thank this.
  5. wfutch79
    313
    454
    Jul 1, 2013
    Already did that. I have a contact at the school that I have been drilling with questions. Figured I would ask here since I probably wont hear from her until tomorrow.
  6. x1Heavy
    34,017
    42,135
    Mar 5, 2016
    Asking the internet gets you 50 different answers. Go in tomorrow and talk to your contact. He or she is what matters. Not the internet.
    dptrucker and wfutch79 Thank this.
  7. wfutch79
    313
    454
    Jul 1, 2013
    You know, I know that .... LOL ... especially this website! Should have known better ...
    x1Heavy Thanks this.
  8. wfutch79
    313
    454
    Jul 1, 2013
    I was mainly asking from a legal stand point but I get what you are saying @x1Heavy .
  9. TheRipper
    TheRipper Medium Load Member
    386
    440
    Oct 27, 2015
    Tucson, AZ
    My med card was done in Dallas, TX. My license is Arizona, where I'm from.
    I don't know the answer to what the school will accept though.
    x1Heavy and G13Tomcat Thank this.
  10. 3MillionMiles
    3MillionMiles Bobtail Member
    18
    11
    Apr 30, 2017
    some companies will accept a DOT physical from any registered to do DOT physicals, doc,EMT, Nurse,clinic..some carrier will make you go to their doc.nurse,emt etc. you can get a physical in any state as long as they are on the DOTs register list.
    As mentioned above do not volunteer any info not necessary, any past medical history that is not affecting you now do not mentions,,if you broke a leg, had a kidney removed do not mention .
  11. Chinatown
    Chinatown Road Train Member
    74,887
    170,664
    Aug 28, 2011
    Henderson, NV & Orient
    Good advice.
    "Do you snore?" (trying to find sleep apnea problems)
    "NO, my wife says I don't."
    If you're a little overweight or have a large neck, many companies will want a sleep apnea test done. This is sometimes required with companies that require another physical because they don't accept your CDL school physical. If this is a concern to you, then apply with companies that don't require another physical.
    x1Heavy and wfutch79 Thank this.
