DOT Physical
Discussion in 'Trucking Schools and CDL Training Forum' started by wayne49ers, Apr 20, 2019.
  1. wayne49ers
    wayne49ers Bobtail Member
    21
    7
    Jun 3, 2018
    Arlington,Washington
    I don't know anything about Dot Physical can someone explain it to me my blood pressure is normally 126/82 will that get me to pass. What else i need to pass?
  3. stayinback
    stayinback Road Train Member
    3,911
    8,256
    Jan 24, 2014
    chicago,il
    You gotta be able to see, minimum 20/40
    You gotta Hear Whispers from a few feet away.
    Make sure your Arms n Legs work, You can Bend Over- doc Grab your Sack,Cough- You Passed!
    Oh You'll pee in a bottle to check Sugars and such
    x1Heavy Thanks this.
  4. wayne49ers
    21
    7
    Jun 3, 2018
    What if my sugar is high where does it need to be? if i pass everything else will i get a 2yr card
  5. stayinback
    3,911
    8,256
    Jan 24, 2014
    chicago,il
    Yeah,I dounno where its supposed to be- I think its more on seeing If your Urine is real Dark Color which means your Dehydrated
  6. Chinatown
    Chinatown Road Train Member
    74,924
    170,779
    Aug 28, 2011
    Henderson, NV & Orient
    You can get your sugars and blood pressure down by watching what you eat and drink plus a brisk walk for 30 or 45 minutes twice a day. With a 30 minute brisk walk I can get my sugar level to drop 50 points.
  7. wayne49ers
    21
    7
    Jun 3, 2018
    Thank you for the information
  8. Siinman
    Siinman Road Train Member
    5,286
    13,377
    Mar 5, 2017
    Kansas City, MO.
    If you have sugar in urinalysis and know it. You can fast for a Couple days and pass. Get your self a glucose tester and check your levels. Normal people should be under 100 after eating.
  9. wayne49ers
    21
    7
    Jun 3, 2018
    Thank you for the tip Siinman
    Siinman Thanks this.
  10. Moose1958
    Moose1958 Road Train Member
    15,169
    33,410
    Dec 17, 2010
    Williesburg, Virignia
    OK, First and most important, RELAX You take this anxiety into that MEs office and you are going to pop the tops off the meter. I can't say this enough, RELAX. You do not want your blood pressure to be any higher than 139/89 Once you hit that 140 you buy a year physical, it hits 90 you hit a yearly physical. It is that simple. The blood pressure you said is good. The FMCSA has got a bit sloppy with this information and it is very hard to find. Still, if your blood pressure is 126/82 it is better then a lot of drivers.
    As to the blood sugar thing. I HIGHLY recommend you fast beginning at around 6PM of the night before the physical. Do NOT consume cola, coffee or tea that evening at all, drink water, in fact drink at least a quart of water. Watch your carbs that night as well. DO NOT EAT breakfast or consume coffee that morning. If you are weak go buy some of those glucose pills at any pharmacy. I keep them with me all the time. What will happen at your physical is they will get you to pee in a cup. They will dip a testing strip in the pee. If there is no reaction your good. If there is a reaction it means your blood sugar is over 160 and you have protein spilling into your urine. If you take it easy with cokes and coffee the day before and watch the carbs and sugar then fast you should be OK.
    If you are very heavy watch out for the sleep apnea thing. Hopefully, you are not.
    x1Heavy and Chinatown Thank this.
