Double Clutch vs. Floating
Discussion in 'Questions From New Drivers' started by JOMO2NC, Mar 24, 2012.
  1. JOMO2NC
    JOMO2NC Bobtail Member
    19
    Jan 22, 2012
    North Carolina
    When I was in trucking school, they made me double clutch. If you float the gears you fail. Now that I'm with a trainer, he won't let me double clutch. He says it's hard on the clutch. He makes me float the gears and I suck at it. I've gotten better, but it's still not perfect. I can double clutch and not grind gears. I grind half the time when floating. I defintitely need a lot more practice.
    Does everybody float the gears in the real trucking world?
  3. 123456
    123456 Road Train Member
    10,555
    5,746
    Oct 22, 2010
    32179
    no..........
    DrtyDiesel Thanks this.
  4. American-Trucker
    American-Trucker Road Train Member
    10,371
    5,085
    Nov 8, 2009
    Charlotte, North Carolina
    yes, most do
    American Trucker
    JOMO2NC Thanks this.
  5. Logan76
    Logan76 Crusty In Training
    4,528
    17,698
    Jul 12, 2009
    kittanning, PA
    Why is this beat to death on this forum?!
    Drive how YOU want, if you want to float do it, if you double clutch that's fine too! It doesn't matter how you shift aslong as your not lugging the motor, grinding gears, shocking the drive train, etc. I'm so tired of seeing this subject beat to death, neither makes you a better driver just drive the #### truck and try not to run over a bus full of kids.
  6. slim shady
    slim shady Road Train Member
    3,468
    14,690
    Sep 14, 2011
    Chicago, Il.
    Only need to double clutch to pass cdl road test, Then forget it and float
  7. Working Class Patriot
    Working Class Patriot Road Train Member
    12,683
    23,165
    Jan 17, 2008
    Wherever and Whenever...
    Double-Clutch when you are training.....
    Double-Clutch when you are taking a driving test for your CDL...
    Double-Clutch when you are taking driving test for a company...
    Double-Clutch when you are driving someone else's truck....
    Float 'em when you know how to properly float the gears and you either own the rig or, you have permission to float them....
  8. Working Class Patriot
    12,683
    23,165
    Jan 17, 2008
    Now the secret to "Floating".....
    Listen to your engine....
    Pay attention to the tach and your speedo...
    Use Two Fingers to shift.....Don't "Man-handle" the tranny....Let the tranny tell you when to pull it out and put it in.....Think of it this way....It's like a woman...Get it?
    JOMO2NC and Boogers Thank this.
  9. American-Trucker
    10,371
    5,085
    Nov 8, 2009
    :biggrin_25524: :biggrin_2559:
    American Trucker
  10. Working Class Patriot
    12,683
    23,165
    Jan 17, 2008
    You read way too much into this......:biggrin_25523:
    American-Trucker Thanks this.
  11. abyliks
    abyliks Road Train Member
    3,885
    9,080
    May 2, 2010
    ludlow MA
    I usually just push the clutch down and then swing my right foot around and kick the stick into whatever position i want, its not my truck what do I care
    :biggrin_25523:
