Double Clutching A 13 Speed
Discussion in 'Questions From New Drivers' started by SprintCar, Jan 21, 2010.
  1. SprintCar
    SprintCar Light Load Member
    61
    11
    Jan 2, 2010
    Arizona
    How far do you have to depress the clutch pedal (beyond free play) when double clutching your shifts? I seem to be botching that deal up and I am not sure if I am not depressing the pedal enough.
    Thanks
  3. Powder Joints
    7,680
    7,771
    Sep 25, 2007
    Rosamond, SoCal
    Try thinking of it as touching the clutch pedal, not far at all. while still accelerating put slight pressure on the gear shift, touch the clutch pedal just far enough for it to come out of gear, maybe 2" or a little less. Thats all it takes. Always remember to preselect your gears on a 13 speed.
  4. saddletramp0538
    saddletramp0538 Bobtail Member
    Columbus, OH
    DOuble-Clutching? if you use the clutch, only use it for lever shifts; rocker shifts are made by releasing the accelerator and reapplying throttle. This will do until you learn to float.
  5. Freebird135
    Freebird135 Road Train Member
    1,527
    906
    May 7, 2009
    In the air conditioning
  6. cactusjack
    cactusjack Medium Load Member
    616
    230
    Aug 2, 2009
    oklahoma
    double clutch?.......
    I might of did that once in 1993 in school just to see what it was like.......
    Chubby Fly Thanks this.
  7. Kabar
    Kabar Road Train Member
    1,041
    395
    Nov 5, 2008
    Pell City Al
    You don't double clutch a 13. You use that clutch to get moving. Maybe a little in 3-4-5 but after that you float it.
  8. Spacer
    Spacer Medium Load Member
    470
    207
    Dec 8, 2008
    Little Rock, AR
    The school I went to in '91 required us to d.c., but after I got out my first real trainer showed me how to float. That's all she wrote since then.
    I've never personally worn out a clutch or a clutch brake. Longest I've been assigned the same truck was 4 years.
  9. jtrnr1951
    jtrnr1951 Road Train Member
    Might surprise you, but even some Very Experienced drivers use the clutch on every shift. Not everyone floats......
    Odin's Rabid Dog Thanks this.
  10. Spacer
    470
    207
    Dec 8, 2008
    Little Rock, AR
    Might surprise whom?
    I know good drivers who do it different ways. Just don't use the clutch much myself. My students would always get pretty much the same treatment from me, and I'd encourage them to find their most comfortable groove (one that was easiest on my truck, preferably), and some students did better with the clutch.
    To each their own, dontcha know?
  11. Freebird135
    1,527
    906
    May 7, 2009
    all i use the clutch for is to start stop and pull it out of gear for a downshift
