Double clutching described by Missouri: Is it accurate?
Discussion in 'Questions From New Drivers' started by Dreamboat, Aug 23, 2015.
  1. Dreamboat
    Dreamboat Light Load Member
    240
    167
    Jun 15, 2015
    JopMO
    I am concerned ONLY with a driving test for CDL. No one told me about step 3--as thought it is a separate thing to do IN BETWEEN. And why would I be slowing down to the RPM required when I am shifting up??? Are the UP and DOWN RPMs reversed?
    The following is right out of the 2015 manual, page 2-9 (except I numbered my lists).
    Basic Method for Shifting Up.
    Most heavy vehicles with manual transmissions require double clutching to change gears. This is the basic method:
    1. Release accelerator, push in clutch and shift to neutral at the same time.
    2. Release clutch.
    3. Let engine and gears slow down to the rpm required for the next gear (this takes practice).
    4. Push in clutch and shift to the higher gear at the same time.
    5. Release clutch and press accelerator at the same time.
    Shifting gears using double clutching requires practice. If you remain too long in neutral, you may have difficulty putting the vehicle into the next gear. If so, don't try to force it. Return to neutral, release clutch, increase engine speed to match road speed, and try again.
    Knowing When to Shift Up. There are two ways of knowing when to shift:
    Use Engine Speed (rpm). Study the driver's manual for your vehicle and learn the operating rpm range. Watch your tachometer, and shift up when your engine reaches the top of the range. (Some newer vehicles use "progressive" shifting: the rpm at which you shift becomes higher as you move up in the gears. Find out what's right for the vehicle you will operate.)
    Use Road Speed (mph). Learn what speeds each gear is good for. Then, by using the speedometer, you'll know when to shift up. With either method, you may learn to use engine sounds to know when to shift.
    Basic Procedures for Shifting Down
    1. Release accelerator, push in clutch, and shift to neutral at the same time.
    2. Release clutch.
    3. Press accelerator, increase engine and gear speed to the rpm required in the lower gear.
    4. Push in clutch and shift to lower gear at the same time.
    McCauley, Puppage and pattyj Thank this.
  3. S M D
    S M D Road Train Member
    2,396
    3,406
    Mar 15, 2012
    sacramento ca
    Sounds about right. Only thing I can a suggest is not to shove your foot to the floor. Just push the pedal 1/4 way or so. After a couple hundred tries it'll become easier.
    I learned to float gears first then I learned how to double clutch. I learned to use my eyes and mind to focuse on the speedo and timing the gear change. Then after all that was down I started practicing double clutch which was fairly easy.
    XFM2013 and pattyj Thank this.
  4. pattyj
    pattyj Road Train Member
    22,474
    20,137
    Jul 19, 2008
    Sioux City,ia
    That's way too much thinken for me,lol.I'm in second I double clutch as im shifting to 3rd so on and so forth.Once you get your own trk or even in trainers trk and get comfortable driving it,double clutching will come easy because you know your trk.
    XFM2013 and truckon Thank this.
  5. lots of character
    lots of character Road Train Member
    1,031
    1,814
    Aug 12, 2015
    Just round all those pesky parts off, eventually it won't grind anymore.
    n3ss, XFM2013, SHOJim and 3 others Thank this.
  6. Dreamboat
    240
    167
    Jun 15, 2015
    JopMO
    Yeah. I've got double clutching; just not very smooth at it--not many chances to practice. Thing is that third step and the words "let engine..." as though I am waiting for something to happen there...
    I have my test tomorrow and am reviewing the manual.
    Floating has to wait until AFTER the test.
  7. pattyj
    22,474
    20,137
    Jul 19, 2008
    Sioux City,ia
    By law schools have to train double clutching but once you get good at shifting you'll probably float the gears meaning you won't need the clutch but to start, slow down, and stop.
  8. pattyj
    22,474
    20,137
    Jul 19, 2008
    Sioux City,ia
    Good luck tomorrow,the thing is don't overthink it and don't focus on the manual too much.Just focus on the test.You got this, just relax.
    Starboyjim and Dreamboat Thank this.
  9. lots of character
    1,031
    1,814
    Aug 12, 2015
    I don't even use it then anymore. Except dead stops and starts.
    I've got an 8LL in my truck, just float down to low then lo-lo on the split
  10. pattyj
    22,474
    20,137
    Jul 19, 2008
    Sioux City,ia
    I drove for a company the trks were so slow and so uncomfortable all I did was float.I hated coming to stop signs and going up hills,took forever to gain speed.
    lots of character Thanks this.
  11. pattyj
    22,474
    20,137
    Jul 19, 2008
    Sioux City,ia
    Its also important you match your rpm's with the motor.You have rpms too high trk wont shift,too low trk will die.
