Double drop deck height
Discussion in 'Flatbed Trucking Forum' started by blazer_72, Nov 18, 2015.
  1. blazer_72
    blazer_72 Bobtail Member
    20
    4
    Nov 18, 2015
    Louisiana
    I need to go get a 2001 T2000 Kenworth the truck does not have the top cap. Can I do this with a double drop deck without oversize permits.
  3. Old Man
    Old Man Road Train Member
    4,597
    13,471
    Apr 3, 2009
    Oklahoma City, OK
    You need to measure the truck, should work. Most decks are 18 to 22 inches high. Stacks will probably nedd to be removed
  4. blazer_72
    20
    4
    Nov 18, 2015
    Louisiana
    Stack is below the cab so that shouldn't be an issue. At what height is it considered to be oversize.
  5. sliver
    sliver Light Load Member
    230
    242
    Feb 17, 2015
    idaho
    It depends on state 13'6" In some states 14 in others
  6. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    13.6 from the ground, most flat/top an some mid/roof can be hauled on step deck with a good tape measure,
  7. TripleSix
    132,697
    If it doesnt have the top cap, it should be 12'4 or lower.
  8. blazer_72
    20
    4
    Nov 18, 2015
    Louisiana
    Ok thanks guys I'll have to get the tape measure out.
  9. johndeere4020
    8,522
    119,294
    Jan 1, 2010
    Make sure you pull in the mirrors on the truck your hauling or they'll pop you for over width.
    macavoy Thanks this.
  10. rank
    rank Road Train Member
    9,919
    113,508
    Feb 11, 2010
    No problem. We were going to pull the fairing off an '05 T2000 to get it on a RGN but on decided on a tow truck instead.
