Double piston top seal flange came off.
Discussion in 'Car Hauler and Auto Carrier Trucking Forum' started by 05vnl670, Dec 3, 2021.
  1. 05vnl670
    05vnl670 Light Load Member
    165
    60
    Feb 17, 2013
    Hello everyone.
    I have question if any one seen the top of the double piston just come off. I was raising the deck on mine truck with small SUV and the top part of the double piston just came off. The part is threaded so the threads just came apart. 2014 Cottrell cx7.
  3. Hammer166
    7,465
    27,081
    Aug 18, 2007
    ~8600+' and loving it!
    I don't think I've ever seen that, but Cottrell cylinders are notorious for pulling the threads on the bottom of single-stage cylinders, especially those on the back of the tip deck on a high rail. They tended to have to exert more downforce when the slip plate aged and they would chatter coming down.
  4. Tropsnart
    Tropsnart Road Train Member
    1,130
    2,384
    Jun 8, 2015
    Pavilion New York
    I had bought a new truck in 2014 and wouldn't you know it, same thing happened to mine. First load out, I was loading the middle top deck and went to lift it. No go. Top threaded cap came apart.
  5. 05vnl670
    165
    60
    Feb 17, 2013
    I'm surprised that the top came off and I know that the pressure is applied under the top cap to retract/lower the cylinder which makes no sense, why it came apart.
  6. CaseRobert
    CaseRobert Bobtail Member
    21
    19
    Apr 21, 2014
    Otsego, MI
    due to the difference is sizes between the piston side and the rod side of the cylinder, you can get a pressure multiplication effect on the rod side of the cylinder which can exert a huge amount of force on the cylinder cap. So if you have anything causing a restriction in the flow of hydraulic fluid out of the rod side, this can cause the cylinder cap to strip the threads and pop goes the cap. This is assuming that the threads on the cylinder and cap were all up to spec.
  7. Howard M
    Howard M Bobtail Member
    Mar 8, 2022
    Yeah, this might occur when an uneven loading takes place. Recently my friend's truck has had the same issue with the cylinder cap. On unloading his goods from the truck his threaded cap came apart it also shows a slight bend in the cylinder and the hydraulic fluid flow out of the cylinder. It is very difficult to manage the situation and then replace the cylinder with a new one.
