Downgrades with no Jake. Best way to handle it?
Discussion in 'Experienced Truckers' Advice' started by EverywhereMan, Jun 29, 2013.
  1. EverywhereMan
    EverywhereMan Medium Load Member
    303
    391
    May 28, 2013
    The North
    Right now I'm back in an older Pete 330 expedite truck with a GVWR of 36k, a semi-auto trans and a broken jake brake. I was heading north from SC last night on the 77 and Route 19, etc, past Fancy gap and a few other downgrades, none too crazy but I thought I'd ask this now while I have the chance. What's the best way to handle these downgrades near the max gross weight, or even empty, with the equipment I'm using? I was usually staying about 5mph under the posted speed limit and using the 'stab' method of gaining 5mph and slowing back down to my 'safe' speed. I found I was using the brakes more than I'd like and I'd gain that speed back pretty quickly. I stuck to what I knew but being wet behind the ears I might have been missing something.
    I'm not really experienced with downgrades as I ran dump trucks in Toronto last year and we have no mountainous terrain here. I did stop at the bottom of one mountain just to check out my brakes, to see if they were hot or if I could smell them, and found nothing. I was frequently checking for smoke going down and thankfully saw nothing also. But I suppose better to be safe than sorry. Any advice, tips or hints would be appreciated.
  3. CDL1968
    CDL1968 Medium Load Member
    345
    208
    Sep 27, 2012
    USA
    You should always drive you truck like you don't have an engine or exhaust retarder. So, just drive it like you were shown in driving school.
  4. areelius
    areelius Light Load Member
    270
    119
    Nov 9, 2012
    Temecula Ca
    Im new to this myself, but my good friend who is very experienced, told me it is a big NO on driving without an engine brake. It would be a catasrophic accident waiting to happen. Trucks have engine brakes because they are absolutely neccessary. I would not take a load in my truck if my jake was inoperable unless it was under 15k lbs. And then I would go down a gear or two on downgrades. If you drive for a company they should not let that truck on the road without all safety equipment in working order.
    seamutt, mitmaks and Tb0n3 Thank this.
  5. Powder Joints
    7,508
    7,416
    Sep 25, 2007
    Rosamond, SoCal
    Well if your brake did not overheat, thenyou did it correct.
    Start out slow, low gear, light brake pressure and take your time.
    Oxbow and MZdanowicz Thank this.
  6. EverywhereMan
    303
    391
    May 28, 2013
    The North
    I didn't go to driving school. Everything I've learned about driving a truck has been from my short experience and the word of other drivers thus far. Never had an accident, no tickets, no violations and I keep my equipment safe and up to DOT/MTO standards. There will be bumps in the road most certainly but so far it's been a great time.
    Jarrod1221 Thanks this.
  7. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    Start in a lower gear then you would with a jake going down the hill. Only use you brakes for 3 seconds to reduce speed, (but hard enough to drop 5 mph) then let it rise back up. If you start running out of air, push brakes harder to slow down more then 5 and use less often giving a chance to build. If brakes start to over heat, brake for a shorter period of time, but more frequently. If you are loosing air and they are over heating, just put the brakes down and stop the truck. Take a runaway ramp if you have to. You can tell if you brakes are overheating pretty easily. if you are pushing harder to get the same braking power your starting to get brake fade, which means they are to hot.
    evd Thanks this.
  8. Ronin_on_MT
    Ronin_on_MT Light Load Member
    245
    95
    Jun 8, 2013
    Porkopolis
    Under your scenario, you would use the same gear going down a grade as you would use going up.
    If it starts running, drop a gear.
  9. brsims
    brsims Road Train Member
    5,296
    6,521
    Aug 8, 2009
    Meadville, PA
    Your friend did you a deep disservice with this lie. There are plenty of trucks out there built without Jake brakes or similar, and even more trucks with top ends so far out of adjustment that the Jake Brake is about as useful as sticking your tongue out the window. The absolute truth is that every driver needs to learn how to handle their trucks without the Jakes. Jake Brakes are not required safety equipment, they are optional equipment that the company pays extra to have installed. Just like the ABS systems on today's cars (generally considered a "standard" option, not a safety necessity), the lack of Jake Brake will not create a Safety Out of Service violation.
    Learn how to drop down a grade without a Jake, and you'll be a better driver overall. It's not that hard, just drop an additional gear or two, and use the combination between the transmission drag and the brakes to maintain control over your speed. Bear in mind that there are some weather conditions where the use of a Jake is not recommended. What are you going to do if you're dropping down Fancy Gap in heavy rain?
  10. Brandonpdx
    Brandonpdx Road Train Member
    4,186
    3,972
    Dec 27, 2007
    Elkhart, IN
    There is no trick. You just have to keep the truck slow enough to where you wont overheat the brakes. Stab method helps, but if you're talking 80,000 lbs with no jake down a long 6%'er, you're crawling along at 10-15 mph.
    If you've ever been down Cabbage/Deadman Pass on I-84 in Oregon, they have a big sign on the westbound side (the fast side) that gives approximate speeds you should adhere to depending on your GVW if you don't have an engine brake. 105,500 it suggests like 8 mph or something ridiculously slow like that.
  11. rockee
    rockee Road Train Member
    1,393
    673
    Apr 17, 2007
    Pacific Northwest
    Bad advice as far as I'm concerned. Why not start out in a lower gear then grab another one if need be, vs. starting off behind the ball?
