Downloading Qualcomm logs
Discussion in 'Questions From New Drivers' started by mirrormirror, Feb 15, 2014.
  1. mirrormirror
    mirrormirror Light Load Member
    94
    63
    Sep 9, 2013
    Looking for help downloading my log report from Qualcomm. I have no problem logging in and displaying the report, but the only option I see is to print. Don't want to print 100+ pages. Supposed to be able download the report as a pdf file. I have Adobe Reader version 11. Has anyone done this successfully?
  3. mclass555
    mclass555 Light Load Member
    184
    88
    Jun 5, 2013
    You should see a place where you can select the number of days you want to view, and in turn it will only print out those number of days.
    And also while viewing the report, you will see a icon at the top, where you can download and save to your harddrive
    mirrormirror Thanks this.
  4. mirrormirror
    94
    63
    Sep 9, 2013
    I've gotten that far, but is print my only option? I want to save it to the computer for easy access and print later if needed.
  5. mirrormirror
    94
    63
    Sep 9, 2013
    The option to save to disk magically enabled itself. Go figure. Thanks wclass555. Problem solved.
  6. mclass555
    184
    88
    Jun 5, 2013
    If you are using internet explorer, right click on document, left click on print, and as for printer, click on the arrow for drop down menu, and select Adobe and then click on print and then select a place to save and it will save it to your harddrive
  7. mclass555
    184
    88
    Jun 5, 2013
    Ok glad you got it to save
