Downshift floating
Discussion in 'Questions From New Drivers' started by Rthiery, Apr 7, 2013.
  1. Rthiery
    Rthiery Bobtail Member
    7
    Apr 2, 2013
    Ok I think I've finally learned floating going up gears but when I hit traffic in Austin and San Antonio I found my self struggling to float downshifting. I'm at about 67k pounds so I've tried to get my rpms up and tried watching the tach but still find myself having to throw it in neutral and recover at 7th or 6th and am grinding like tony hawk. Can someone with more experience help me out? Thanks
    AchioteCoyote Thanks this.
  3. G/MAN
    G/MAN Road Train Member
    7,031
    8,622
    Sep 3, 2010
    Your rpm's need to be higher downshifting than upshifting. You NEVER want to force your transmission into a gear, up or down. You should be able to downshift at around 1500-1700 rpms.
    AchioteCoyote and Kickstand-117 Thank this.
  4. Okieron
    Okieron Crusty Okie
    1,641
    1,024
    Dec 23, 2009
    muskogee, ok
    Try going over a LITTLE bit and let it come down when it slides in you know where your window is. also listen and you'll learn to do it by ear.
    Kickstand-117 and Rthiery Thank this.
  5. skellr
    skellr Road Train Member
    8,737
    12,185
    Jul 17, 2011
    The Village, Portmeirion
    Next time your putting along off the interstate and you shift try to downshift back to the previous gear. keep shifting between the two gears and you will get a feel of how much you need to bump the throttle. listen to the sounds, you'll get it.
    Rthiery, jowsuf, Lepton1 and 2 others Thank this.
  6. Powder Joints
    7,663
    7,743
    Sep 25, 2007
    Rosamond, SoCal
    It is exactly the same principle as shifting woth the clutch, you must match your rpms with the road speed. First learn to shift period. If you learn to shift correctly you will be better than 75 percent of the driver on the road.
    400 rpm differential between the gears.you have to drop road speed first, till your down to say 1100 rpms, alide into nuetral, bring your rpms up to 1500 and with gentle pressure i will slide into the next gear down.
    jparm, newbie driver and Rthiery Thank this.
  7. TripleSix
    129,492
    Perhaps it's the location. Nobody likes driving between Austin and San Antonio.
    arata954, n3ss, NewNashGuy and 3 others Thank this.
  8. hawkjr
    hawkjr Road Train Member
    1,652
    638
    Feb 28, 2010
    Virginia
    Beats being in between New York City and New Haven, CT
    Rthiery, newbie driver, Honch and 3 others Thank this.
  9. muff
    muff Light Load Member
    73
    38
    Dec 20, 2010
    ontario,Can
    Agreed ! That`s why they make automatics. Too many drivers can`t shift and are too lazy too learn . Give it time Rithiery it will come. Do they ever make a bang when you top a gear ...lol. Ouch
  10. MJ1657
    MJ1657 Road Train Member
    7,521
    50,151
    Jan 28, 2012
    Isanti, MN
    Do it by feel and sound ignore the tach.
    Rthiery Thanks this.
  11. ethos
    ethos Road Train Member
    4,249
    9,905
    Mar 3, 2013
    Houston
    I had a truck once that just would not float, no matter what I tried. All the advice on here is good, just practice, you will get it.
