So I have a code 3251 on 2013 international durastar. From what I have been told they could be various issue. However with blowing smoking little bit more often, black spot on exhaust pipe and occasionally sound of small metal rattle noise. With all that I assuming ios the dpf
Dpf failing
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by eaglesweeper, Jul 31, 2019.
I’m not sure what that code is specifically, that would help. Black spot on exhaust pipe, where? There’s quite a few junction points. That could be anything from a lose clamp to maybe a ill functioning egr valve, to a clogged doc/dpf causing high back pressure.
You should be able to plug into a computer and check the after treatment backpressure readings to check the status of the dpf/doc. The filters tend to be in that $3000 range, and even cleaning them can result in mechanic damage to the filter, cracking it, and causing a needed replacement. I’d say, check the code- see what it stands for and check the computer read out for after treatment back-pressure; to see if it’s within tolerance or out of spec -
3251 is only the SPN part of the code. What FMI are you getting?
Off the top of my head ( not fact checked) 3251 is a after-treatment inlet pressure code. If thats the case, and with the sound it’s making, this is probably the case.
If it where my truck, I would take the DPF out and DOC and blow them out backward with shop air and put it back together if the DOC’s cant be removed, figure out a way to attach a vacuum to the front of it and vac while you blow. ( you may want to do this anyway to reduce the mess. Put it back together and see what you got.
You can do this without a computer and see if the code “heals itself” after this operation.
This won’t address the reason for the soot but this might save your, exhaust system for the time being.
