DPF question. New to trucking.
Discussion in 'Questions From New Drivers' started by LoneRanger, Jun 3, 2018.
  1. LoneRanger
    LoneRanger Road Train Member
    3,675
    9,541
    Jun 3, 2018
    Hi guys, I’m new to the field. I’m in the process of getting a truck but I have a question. I do not plan on visiting California and would like to get a newer truck without dpf or def. Is that even possible without a delete kit?
  3. Brickwall
    Brickwall Light Load Member
    292
    381
    Jan 30, 2018
    It is possible, it's called a glider. Do some research first, because there are bith pros and cons to doing so.
  4. Brickwall
    292
    381
    Jan 30, 2018
    And if you're "new to the field" then buying your own truck is a mistake. It will bankrupt you.
  5. LoneRanger
    3,675
    9,541
    Jun 3, 2018
    So that’s what a glider kit does? I will do that. Thanks
    I appreciate the advice.
  6. Cam Roberts
    Cam Roberts Road Train Member
    1,621
    1,938
    May 13, 2018
    As already mentioned, you will want a glider. There is plenty of companies that will build you one but it’s gonna take several months. There are plenty of cat heavy equipment dealers that are in the game of building gliders now as well. Smart first bussiness decision you have I should ad. New truck with full warranty and long life of motor with no issues at all
    LoneRanger Thanks this.
  7. Cam Roberts
    1,621
    1,938
    May 13, 2018
    Glider kit is just a rolling chassis bought of peterbilt or whoever you decide to buy from. Motor and trans added to your spec and your ready to rock and roll
  8. Cam Roberts
    1,621
    1,938
    May 13, 2018
    It will bankrupt people with low education and pipe dreams but will not bankrupt people that are dedicated and have prepared for it
  9. LoneRanger
    3,675
    9,541
    Jun 3, 2018
    I was about to ask you exactly what a glider kit is but you already knew that huh?
  10. Cam Roberts
    1,621
    1,938
    May 13, 2018
    I figured brotha. It comes with everything you need. Brakes tires rears etc etc etc. just ad drive train
  11. LoneRanger
    3,675
    9,541
    Jun 3, 2018
    I appreciate the info.
    I want to point out I’m might be new to driving I’m not new to running a business.
    I’m having someone else run my company while I try something different.
    So financially I’m ok.
    Also first truck will be a used one until I learn the ropes.
