DPF regeneration during stop/go
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Victor48, May 27, 2012.
  1. Victor48
    Victor48 Bobtail Member
    10
    Sep 28, 2011
    Truck mostly runs locally in slow traffic. No DPF lamp or any other notifications that DPF regeneration is required. It starts automatically in stop/go traffic.
    You only know that regeneration has begun because of increased idling RPM and HEST light ON sometimes. Regeneration is constantly interrupted when stopped.
    Can I ignore this and keep driving stop/go? Will this cause any damage? Or should I stop regeneration and wait for highway or when able do Parked? For how long I can keep switch in Stop position?
    Thank you.
  3. freightlinerman
    freightlinerman Road Train Member
    1,287
    536
    Mar 4, 2011
    Florida
    How do you think transit buses do it? If you're in slower traffic, use a lower gear to get higher RPM's. Or maybe try raising RPM's if you're in neutral.
    Victor48 Thanks this.
  4. Heavyd
    Heavyd Road Train Member
    7,751
    6,184
    Feb 4, 2009
    We know with Internationals and trucks that are mostly stop and go, like garbage trucks, that stop and go is the hardest on the entire DPF system. Passive regens, (regens that take place during normal driving), aren't too effective either with stop and go type of applications. This leads to faster than normal system plugging and the need for more frequent regens, which can lead to further plugging if the system doesn't get a good chance to get and stay hot. Some trucks have a "Regen Inhibit" switch that will prevent the system from regens during times like you mentioned. All you really have to do is just watch for your DPF warning lights and do a parked regen when the system is requesting it. Call your local dealer with your vin and see if there are any new engine calibrations to improve the aftertreatment operation. These get updated all the time and really do help!
