drain air tanks every day the easier way
Discussion in 'Experienced Truckers' Advice' started by crucar1800, Apr 15, 2019.
  1. crucar1800
    crucar1800 Light Load Member
    186
    71
    Sep 21, 2012
    Draining air tanks averyday after your shift is important. It helps the air system and it's components to function efficiently.
    Here is an easier way to drain them out in three minutes. All we need is an elastic cord and an air hose cleaner attached to the drivers seat. Take a look at the images for quick set up.
    Cord attaches to two drain valve cables without stressing and over pulling the system. It has to be a mid size/lenght cord. Not the longest and not the shortest. Do not over pull the valve cables. They do brake.
    Air cleaner hose attaches to the seat which takes air from the second tank.
    Remember to change air dryer filter every nine months to avoid moist in the air system.
    IMG_20190414_210342315.jpg IMG_20190414_210350499.jpg IMG_20190414_212922155.jpg
  3. So what do I do if my Peterbilt doesn't have that flippy plastic below the seat. Mine is screwed on.
    @OLDSKOOLERnWV
    062, OLDSKOOLERnWV and Grubby Thank this.
  4. D.Tibbitt
    148,720
    I just put a bungee cord on mine and hook it to my side box , then walk in the truck stop come back and its drained
    x1Heavy, Grubby and Lepton1 Thank this.
  5. OLDSKOOLERnWV
    18,367
    276,563
    When I pull the cables on my tanks which are behind the sleeper, I pay attention to see if anything comes out other than moisture and air. Never know when the compressor is needing attention.
    @crucar1800 what is the blow nozzle for? I’m not understanding what it’s for sorry. I know some guys blow their pants legs and boots off before getting in the cab, and blowing dirt out of the floorboards. I’m not understanding it’s purpose in draining the air tanks.
    Brettj3876 and 062 Thank this.
  6. Espressolane
    17,547
    107,503
    Have lanyards on the tank drains. Pull them to drain tanks. Pull and hold for a minute, if water sprays, hold longer for water to stop.
    If your air system is working properly, you should have very little moisture in the system.
    starmac and 062 Thank this.
  7. 062
    062 Road Train Member
    6,216
    33,465
    Oct 20, 2013
    Geez do we have to do everything for you. You go buy a truck with the flippy plastic and while you’re at it pick up some white tape to wrap around the fitting on the blow nozzle.
  8. gentleroger
    gentleroger Road Train Member
    7,458
    20,275
    Jun 1, 2010
    You don't need to completly evacuate the tanks at end of day. A quick pull of the drain cords is all you need. Also most cascadias have a third tank drain mounted at the back.
    If I did need to drain thr tanks, why not just pump the brake pedal? Takes less tine than rigging up a bungee.
    Tb0n3, D.Tibbitt, kylefitzy and 3 others Thank this.
  9. Grumppy
    3,089
    10,595
    Dec 11, 2010
    West Monroe, La
    If you have that much water in your tanks that you need to drain your tanks everyday, you need a new air drier, not a bungee cord jeri-rig. Draining your tanks once a week with a properly operating system is more than enough. I only drain my tanks about once a month & I don't get enough water out to even know if there is really any water in it.
    And as @gentleroger said, you don't need to completely drain the tanks. The water is all on the bottom & a quick 2 second pull on the cord that comes on the truck is sufficient. Again, if you have enough water in your tanks every day where you have to hold the drain open more than a couple of seconds, you got a bigger issue than needing to rig up a bungee cord.
    Tb0n3, starmac, Ezrider_48501 and 5 others Thank this.
  10. 201
    201 Road Train Member
    12,334
    25,217
    Apr 16, 2014
    high plains colorado
    I agree, quick pull on the cable is all you should need. The days of before air dryers, where you'd get a puddle of that gray matter every day, are over, thank heaven. You youngun's have no idea how good you got it.
    Far as pumping the brake pedal, I don't think that would do it, as water tends to go to the lowest point.
  11. jammer910Z
    jammer910Z Road Train Member
    2,446
    6,522
    May 28, 2015
    AMEN. I remember the grey porridge well.
    201 Thanks this.
