Dreaded Air in fuel line....
Discussion in 'Volvo Forum' started by v6killer, Nov 6, 2014.
  1. v6killer
    v6killer Medium Load Member
    446
    122
    Dec 6, 2010
    ChicagoLand
    once I get my truck started it will run all day, after I sit for 10 minutes or ten hours, I lose my prime. I do see small bubbles appearing in my water and fuel separator more like small form bubbles. I know the fuel system is sucky air where do I begin, I did notice when I use the prime plunger and the main filter to prime the system it leaks fuel out of the plunger, in my opinion if it's leaking fuel it's sucking air.
    Is there any other places where I should be looking, did replace the fuel pump still the same problem, next on my list is the main fuel filter assembly?
    Any suggestions would be appreciated
    shatteredsquare Thanks this.
  3. rolls canardly
    rolls canardly Road Train Member
    1,599
    3,728
    Feb 7, 2009
    mt. pocono. pa.
    Rolls Canardly here,
    As a general rule there is a check valve on fuel line before head. replace it.
    I had this annoying problem also and changed mine out and it was fixed.
    3126 Cat motor has it threaded into back of head; Don't know on Volvo,
    you need 6 foot gorilla arms to get back to it, but it threads right out.
    Mine was a right angle elbow fitting w/ body made of brass
    that must have a disc and spring for the one-way action.
    Barb fitting on end fits the blue plastic fuel hose; don't forget a clamp over the hose.
    My kid, (40 Y.O. - kid? whatever,) did the change out on mine, and it sucked air around the barb without a clamp.
    Good Luck, Happy Motoring,
    Rolls canardly
  4. nikmirbre
    nikmirbre Road Train Member
    5,376
    9,583
    Jul 27, 2011
    High Point NC
    When I had mine....had same issue......it was sucking air at the fuel primer..... Same symptoms also
  5. Neilwhayes
    Neilwhayes Bobtail Member
    30
    25
    Jul 8, 2014
    miramichi nb. canada
    i had exact same problem, 07 d12, leaking from plunger, air bubbles in davco. i changed the filter housing where the plunger is. the problem was cured.
  6. v6killer
    446
    122
    Dec 6, 2010
    ChicagoLand
    I change out the plunger housing today and still have air bubbles coming into the davco unit. still can't find where am pull air in the fuel line from ?
    replace the fuel pump and main fitter housing.
    any suggestion ?
  7. QUALITYTRUCK
    1,801
    1,762
    Jun 14, 2009
    romulus,mi
    Sorry v6.sounds like the dreaded D12 injector cup issue.
  8. Johny41
    Johny41 Road Train Member
    1,192
    1,020
    Feb 10, 2011
    Ontario, Canada
    yep, I had this long cranking losing prime 4 times with my D13; ; I wasted $ on fuel pump, fuel filter housing but every time was the cups;
    D12 doesn't have ultra high injection pressure and less problems with cups; but buddies of mine with D12 did have same problem with cups at higher mileage;
    shatteredsquare and Intothesunset Thank this.
  9. v6killer
    446
    122
    Dec 6, 2010
    ChicagoLand
    Here is the update on my air problem, the green zip tie is where my air was coming into the fuel system, not the fuel injecter cups ! Had a crack in the line at the Y contion. Just cut about an inch of tubing off and restilled back on.
  10. SGTSmokdU
    SGTSmokdU Light Load Member
    179
    94
    Jun 5, 2012
    Alabama
    Care to repost that pic?
    x1Heavy Thanks this.
  11. Timu djin
    Timu djin Bobtail Member
    9
    Hi, Nik. Did you have problems with power loose, rattles and shaking?
