Drive shaft broken into two pieces while stopped at a stop sign.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Jag.s, Aug 19, 2021.
  1. Jag.s
    Jag.s Bobtail Member
    18
    12
    Jul 5, 2020
    I guys i am just wondering what could have caused to broke my tractor drive shaft into two pieces.
    I just stopped at a stop sign and boom. Dead.
    D.Tibbitt Thanks this.
  3. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    "? Were you pressing on the fuel pedal when you let out on the clutch at stop sign? Or the truck was over loaded at one time or another and started a crack in drive shaft and that stop sign start finished it off?
  4. 201
    201 Road Train Member
    12,641
    25,970
    Apr 16, 2014
    high plains colorado
    Holy Crap, driver abuse! Come on, be honest, you're among friends, get a little aggressive adjusting tandems? Hard to say, could have just been a defect. Once, a guy I knew worked at a diesel shop, guy comes in, says he has a bad vibration. When he brought the truck in, the driveshaft had "corkscrewed" and he was still driving it! I did a lot of dump truck, and never saw a driveshaft break like that.
    Roger McG and D.Tibbitt Thank this.
  5. D.Tibbitt
    153,367
    Are u one of the guys i see pressing the fuel pedal to floor after the light turns green, twisting the chassis all up for no reason. The only way that would happen is from abuse
  6. Ffx95
    Ffx95 Road Train Member
    1,369
    2,632
    May 18, 2017
    I’m not seeing any rust. So I’m betting on driver abuse, overloading, or it was defective.
  7. Cattleman84
    Cattleman84 Road Train Member
    9,999
    71,348
    Nov 1, 2017
    The Sticks, Idaho
    The only time ive seen that kimd of damage has been when a driver disnt know how to drive a big truck properly... He had a tendency to give throttle while letting the clutch out... And not just a little. He was also one of those guys that gave so much throttle that the drivers side steer would nearly lift off the ground with every shift through the first 5 or 6 gears.
    If that is what caused this... Then feel lucky it wasnt an input shaft. Ive seen them twist off from the same type of abuse.
    201 and D.Tibbitt Thank this.
  8. Cattleman84
    9,999
    71,348
    Nov 1, 2017
    The Sticks, Idaho
    Exactly my thoughts
  9. Ridgeline
    22,636
    120,662
    That looks like a shear, not a twist and that means someone doesn’t know how to drive.
    Cattleman84 Thanks this.
  10. REO6205
    REO6205 Road Train Member
    13,168
    60,495
    Feb 15, 2014
    California.
    How old is the driveline? Have you had the truck since new? If not, how many miles have you put on it? The driveline has been abused, either by you or the drivers before you.
