Drive tires recommendations? What do you run on your truck?
Discussion in 'Ask An Owner Operator' started by Dino soar, Aug 30, 2021.
  1. Dino soar
    Dino soar Road Train Member
    4,789
    26,858
    Dec 8, 2017
    I have a tire that is swelling and I might as well replace my drives.
    They were good enough to get me started but I knew the time was going to come sooner or later that I just would replace them. Even though it's just one tire at this point I think I would just rather replace them all.
    I do not nearly put the miles on that you guys put on your trucks. So I'm not looking for a super crazy high price top tier Tire.
    But I am also not looking for cheap Chinese junk that is just problematic right as soon as they get put on. I don't want any tires they're just out of round as soon as they're put on to the rim or any of that nonsense.
    I need more of like a middle-of-the-road tire that will ride right and wear right. Like Dayton or Cooper?
    I have to call around to tire shops tomorrow and see what they have available but just curious will you guys use and if you have any prices that would be helpful too.
  3. jamespmack
    213,767
    Yokohama, Kelly, Toyo, Hercules. That would be my top choice on something that will dry rot before worn out.
    I live 30 miles from Cooper/Roadmaster headquarters. Have friends that have, or do work there. Had one set on drives starting out, did ok at best. But tried a set on pickup, and a car years back. Spent more time putting air in them than driving them. The have the ability to build a good tire. But seldom do.
    They change quality with thier stock value.
  4. Dino soar
    4,789
    26,858
    Dec 8, 2017
    Yes that is exactly my situation.
    Something that will dry rot before it wears out.
  5. jamespmack
    213,767
    I 100% value Michelin tires. But its not cost effective to guys like my farmer buddy who drives under 10,000 miles a year. Have to work with in your means and not be stupid about it.
  6. mslashbar
    mslashbar Medium Load Member
    599
    802
    Jul 22, 2009
    elizabeth,co
    Tire inventories out west are really low. It's not a matter of what you want, but what's available. Hope it's better out where you're at
  7. Midwest Trucker
    5,871
    21,125
    Aug 31, 2018
    If I ran less then 50k a year then I’d probably go with Hankooks, Kelly’s, or Yokohama’s. Especially if you keep in a 300 mile range where heat or fuel mileage is negligible. Good luck friend.
    Otherwise you know I love my Bridgestone and Michelin’s. :)
  8. Long FLD
    Long FLD Road Train Member
    11,400
    46,090
    Mar 4, 2015
    I’ve had good luck with Hankook DL12’s in the past. Currently I have about 100k on a set of Cooper Roadmasters, my local shop was running a sale on them last year when I was in and out of dairies and feed lots all the time. So far I’ve had no issues with them.
  9. TJB15
    TJB15 Light Load Member
    67
    115
    Apr 29, 2020
    I have had excellent results from Yokohama 517
  10. Spyro2112
    Spyro2112 Medium Load Member
    602
    412
    Mar 17, 2018
    All good year, just raised their tire prices 100.00 or do. Fyi
  11. D.Tibbitt
    141,316
    Check out double coins as well. Had good use out of them on my trailer running up and down gravel roads, i put alot of abuse on my tires and so far double coins are the only ones thats held up . im going to try them on the drives my next set
