Drive Tires- replace all or only what is needed
Discussion in 'Ask An Owner Operator' started by White_lightning1983, Feb 1, 2020.
  1. White_lightning1983
    White_lightning1983 Light Load Member
    54
    27
    Aug 1, 2019
    I was wondering if anyone has any experience in this... I have 4 tires that need to be replaced soon. And the other 4 have between 4-6 tread left. The other tires have 2--4 tread left.. I was wondering if it's better to get the same tire for each axel and not mix match any of them. I plan on using a high end tire brand for my drive tires. Right now I have Goodyear tires.
    blairandgretchen Thanks this.
  3. bryan21384
    bryan21384 Road Train Member
    15,388
    33,470
    Sep 18, 2009
    Memphis, TN
    If you can replace all 8, go for it...if not, put 4 new ones on one axle then replace the others down the line. If your old ones are still good and you for your own trailer, put em there for a while
  4. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,140
    Mar 5, 2016
    White County, Arkansas
    I usually have all 8 replaced annually just prior to winter. Older best of the bunch go to trailer spares.
    Flat Earth Trucker and D.Tibbitt Thank this.
  5. Rideandrepair
    17,430
    56,539
    Aug 8, 2015
    My experience is the rear axle tends to wear slightly faster, usually right rear more so, A set of 4 on the rear axle, Then moved up, and again a new set of 4. With a little planning, you can keep a fairly good match up, between axles. Sometimes running the 4 older ones out in summertime. Then replacing them, can end up in a closer match eventually. Keeping the same brand, helps when rotating, if you end up blowing a sidewall or some other road hazard. Otherwise, I do it that way mainly to save the cost of rotation. Applying it to the next tire purchase. The other option is to get a good trade in price for old tires. Depends on the Dealers Market.
    Dino soar and D.Tibbitt Thank this.
  6. 201
    201 Road Train Member
    12,621
    25,905
    Apr 16, 2014
    high plains colorado
    Always a tough call. If you put only 4 on, they might wear faster with the older ones. If you don't have a trailer, and they're virgins, a tire shop may give you something for them, but I'd probably go with 8, and get it over with. And being the negative Joe that I am, the tire companies probably engineer in their tires NOT to be compatible with others. I once thought of buying 10 steer tires, that way, if you picked up something on the steer, ,just plug it, and take one of the drive tires.
    feldsforever Thanks this.
  7. fortycalglock
    fortycalglock Road Train Member
    6,158
    6,592
    Jun 25, 2011
    Tourist Town, FL
    If your meatier tires only have 4-6, replace all 8. I haven’t bought drive tires in a while as my glider still has tires it came with, but the Goodyear g572 was a solid drive tire for me, as in lasting over 500,000 miles.
