Driveline vibration under load
Discussion in 'Trucks [ Eighteen Wheelers ]' started by CbarM, Sep 26, 2013.
  1. CbarM
    CbarM Heavy Load Member
    894
    247
    Jan 17, 2011
    Irvine, AB
    Ive got a vibration thats gettin worse. Mostly when Im on the pedal n a lil bit when Im coasting. U joints are full of synthetic grease n appear to be tight. What else might it be?
  3. truckon
    truckon Swamp Thing
    4,775
    15,915
    Dec 16, 2011
    Like I'd tell you!
  4. CbarM
    894
    247
    Jan 17, 2011
    Irvine, AB
    How can I check to see if thats the issue?
  5. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    The load leveler rod off a hair might have the drive shaft in a bind.
    Two midgets wrestling in the bunk? :)
  6. truckon
    truckon Swamp Thing
    4,775
    15,915
    Dec 16, 2011
    Like I'd tell you!
    I'd take it in to get looked, mine was just wore out and I was getting vibrations pulling hills and on take off...
  7. Heavyd
    Heavyd Road Train Member
    7,752
    6,185
    Feb 4, 2009
    Some times an injector that is just starting to fail with cause issues like this, it will feel just like a driveline vibration.
  8. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    wore out motor mounts can cause this especially the rear. just had that problem fixed after years if vibration. vibe is now gone. it shakes rattles & bounces, but no vibration.
    MARE Thanks this.
  9. D389
    D389 Light Load Member
    99
    56
    Mar 24, 2013
    Texas Panhandle
    Carrier bearing might be bad or the rubber around it has broken down. If there is any play in it the driveshaft will whip around under load and during deceleration.
  10. stranger
    stranger Road Train Member
    3,640
    4,959
    Oct 10, 2006
    NC
    Loose yoke? I know this usually vibrates more in between pulling and coasting, but it will vibrate. Check your ride height. Your leveler valve may be going out, or worked itself out of adjustment.
    Also, have you dropped the clutch hard under a load lately? If so, you could have twisted a driveshaft, and a U-joint doesn't have to flop around to be bad. There can be grooves worn it it from dry needle bearings and feel good.
    baha Thanks this.
