Driver-made bulkheads
Discussion in 'Flatbed Trucking Forum' started by IluvCATS, Nov 25, 2017.
  1. IluvCATS
    IluvCATS Road Train Member
    4,091
    8,976
    Dec 1, 2014
    Seattle, WA
    Have timber and chain bulkheads ever really saved the day? I build them but often wonder how effective they would really be again a sudden load shift. I don’t know.
  3. MACK E-6
    48,145
    219,822
    Where would you need something like that, save perhaps on poorly loaded steel where you'd have to worry about part of the load walking out?
  4. IluvCATS
    4,091
    8,976
    Dec 1, 2014
    Seattle, WA
    That’s what I’m asking. Do they ever save a life as the last thing to stop steel or a coil?
  5. MACK E-6
    48,145
    219,822
    Structural steel, perhaps. But I can't see that stopping a coil. That is a hell of a lot of kinetic energy.
    luddybuddy and IluvCATS Thank this.
  6. Naptown
    Naptown Road Train Member
    1,156
    2,983
    Oct 18, 2009
    Indiana
    They helped me out a lot when i did mixed steel loads and had lots of bundles of varying sizes. No matter how hard you work to get everything tight, sometimes one would work loose. It was always a nice safeguard for just in case.
    They were definitely a must when I had on cold finished bars. That stuff is slick enough it doesn't need a hard brake to slip everywhere, no matter how well it's secured.
    Joetro, MrEd, MACK E-6 and 1 other person Thank this.
  7. Cummins_444
    Cummins_444 Medium Load Member
    605
    1,014
    Apr 28, 2008
    Northwest, IN
    Yep they work. Haul greasy steel bars. Build the bulkhead then load up against it. Choke the load. In a hard brake situation you still might crack the bulkhead, but done properly should move very little.
  8. stayinback
    stayinback Road Train Member
    3,911
    8,255
    Jan 24, 2014
    chicago,il
    Can't remember their name but, There's a place down in St.Louis that ships those 20 foot greasy steel bars that require 2 Bulkheads,Because they wont load it Belly for safety reasons...........
    then after you set up 2 bulkheads- You gotta drop paper......#### pain in the Butt for a Broker load comin back to Chicago for a measly $700 bucks,, boy Do I remember that so well
    baha Thanks this.
  9. Zeviander
    Zeviander Road Train Member
    4,887
    36,995
    Jan 23, 2015
    Winnipeg, MB, CA
    A bulkhead isn't supposed to "catch" a moving load, it's supposed to prevent it from moving in the first place. It's a "block against forward movement". Not having the load touching it will only slow down whatever starts moving through it.
  10. tommymonza
    tommymonza Road Train Member
    4,519
    12,848
    Sep 10, 2013
    S.W. Florida
    I have kinda wondered why flat beds don't have stake pockets welded to the trailer beams every couple feet running down the middle of the bed.
    Than have a movable bulkhead that could be tied back from the top running down to the side pockets.
    That way you can prevent the energy from being built up in a deceleration and seems the only practical way to manage slippery steel.
  11. Tug Toy
    Tug Toy Road Train Member
    6,932
    72,427
    Jul 4, 2015
    Corn field
