Drivers adjusting brakes
Discussion in 'Ask An Owner Operator' started by JonasTtrucker, Jun 7, 2018.
  1. JonasTtrucker
    JonasTtrucker Light Load Member
    53
    Apr 26, 2018
    St. Louis, MO
    What are your opinions in regards to drivers being required to adjust brakes as part of a pretrip inspection. With slack adjusters working properly it shouldn't be a big issue, but all trucks seem to need adjustments at one point of another. Instead of the mechanic adjusting at certain intervals is it better to have the drivers do that?
  3. Broke_and_Hungry
    Broke_and_Hungry Light Load Member
    224
    509
    Feb 26, 2008
    It would be important to document their qualification.
    396.25
    Justrucking2 and tscottme Thank this.
  4. wis bang
    wis bang Road Train Member
    3,368
    3,956
    Jan 12, 2011
    Levittown, PA
    You need a brake training certification to be legal. An owner can adjust his own but not a driver unless qualified
  5. skallagrime
    skallagrime Road Train Member
    3,846
    9,908
    Apr 10, 2012
    Indiana
    Personally I think it depends on the driver, it's not a good policy if that's what you mean. if you have to do it with a vehicle with automatic slack adjusters, you're actually damaging them more than they already were in the first place (if youre adjusting, a. They're broken, or b. They weren't installed correctly)
    Dino soar, Tb0n3 and LoneCowboy Thank this.
  6. Oldironfan
    Oldironfan Road Train Member
    5,777
    5,541
    May 22, 2017
    Proper working auto adjusters do not need adjusting. Keep them greased. According to bendix.
    $100 parts do not last forever.
    Dino soar Thanks this.
  7. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,768
    Mar 5, 2012
    Ontario Canada
    I wouldn't want a driver doing it unless qualified or I am comfortable he knows what he's doing. Good chance do it wrong and now you have a wreck and huge mess on your hands.
    Another reason disc brakes are superior.
  8. Ridgeline
    22,288
    115,123
    No way!
    One of my drivers early in my business adjusted the brakes, because he thought they were out of adjustment. This truck got all new slack adjusters before it was handed over to him.
    So ...
    I am sleeping after working 14 hours in a friend's place where it is 100 degrees in the shop and the ******* phone rings, it is this driver, he is on the side of the road in Kentucky with a tire on fire. Brainiac asked what should he do and told him to unhook the trailer before he loses the load, he hung up on me so he could unhook it, he called back to tell me he yanked on the fifth wheel release and pulled the truck out from under the trailer which the dollies collapsed. Then he asked what else he needs to do, I asked him if he called 911, he said no, so I told him to call them now.
    This is the reason why you don't let drivers adjust the brakes.
  9. rbrtwbstr
    rbrtwbstr Road Train Member
    3,361
    7,723
    Jul 11, 2012
    in the bush somewhere
    Really no reason to have drivers adjusting brakes, if there's a good maintenance schedule in place. And a good driver that can tell when things aren't right helps as well.
    From a practical standpoint, could you imagine if we were still using manual slack adjusters today? There would be dead drivers everywhere, they'd be too lazy to adjust them. Either that or they'd get stuck under the truck due to their gallon of diet Coke a day habit.
    Some things are just better left alone.
    Justrucking2 Thanks this.
  10. Ridgeline
    22,288
    115,123
    My driver read my post, he remembers the guy ... but he said I left out the little instruction sheet in the drivers package, it says you adjust the brakes by pressing on the brake peddle. I have to dig a copy up to post it, it just follows bendix instructions.
  11. TallJoe
    TallJoe Road Train Member
    7,490
    16,271
    Apr 12, 2016
    Chicagoland
    They should be able to do it just like a fisherman needs to know how to gut a fish. Those who don't are inept and need to be kicked in the ### for not knowing how to do it. That's my opinion.
    This should be a part of a CDL exam - demonstrating how to adjust brakes. Mounting snow chains too.
