drivers leaving pump on
Discussion in 'Truck Stops' started by buzz1670, Aug 16, 2012.
  1. buzz1670
    buzz1670 Light Load Member
    205
    857
    Dec 31, 2009
    ny
    seeing more of this latley.a driver sets the handle catch on and hangs up the nozzle.another driver pulls up and if not paying attention flicks the pump on ,diesel everywhere.why would a driver do this to another driver?this bs gets out of hand the EPA will have you fueling one tank at a time,no auto shut-offs anymore.
  3. IceCreator
    IceCreator Medium Load Member
    314
    113
    Jul 3, 2012
  4. Ben Gunn
    Ben Gunn Medium Load Member
    640
    375
    Oct 30, 2011
    Forgotten Coast
    Some people are simply douche bags.
    -insert name- Thanks this.
  5. fortycalglock
    fortycalglock Road Train Member
    6,160
    6,601
    Jun 25, 2011
    Tourist Town, FL
    It happens, usually on the satellite pump side as the driver turned off the main pump and simply put the satellite nozzle away. Most cases of this happening are just a driver being careless, not sabotage. After it happens to you once, it becomes routine to make sure the nozzle is off before you activate the pump. It's really not a problem if you aren't careless yourself. I had it happen to me about 10 years ago, and never since though I've found a locked on nozzle probably a dozen times.
    aiwiron Thanks this.
  6. pilottravel2002
    pilottravel2002 Medium Load Member
    688
    156
    May 25, 2011
    Tucson,az
  7. DrtyDiesel
    DrtyDiesel Road Train Member
    5,348
    2,598
    Feb 14, 2010
    Jacksonville, FL
    I took advice to what another driver had said on here about putting the nozzle in the tank before turning the pump on. I do that from now on
    Ethan
  8. 25(2)+2
    18,756
    45,804
    Sep 18, 2006
    the road less travelled
    Most nozzles will shut off as soon as there is no pressure, I have only rarely found one still on. I'm not saying it never could happen, but the auto shut off feature wouldn't likely work, as advertized, either.
    This problem more likely when it is cold out.
    DrtyDiesel and aiwiron Thank this.
  9. -insert name-
    -insert name- ATM squishier
    1,293
    633
    Jul 12, 2012
    SOMEWHERE
    Did you hear of the driver that couldn't find where to put the nozzle on the truck?
    Thread being hijacked in 3 2 1
    Kidding, but this something annoys the hell out of people who just had a shower not to long ago.
  10. aiwiron
    aiwiron Road Train Member
    5,927
    5,228
    Aug 24, 2011
    Sunny Tampa Florida
    I always check and put the nozzle in the tank even before carding the pump.
  11. RAGE 18
    RAGE 18 Road Train Member
    1,529
    941
    Jan 31, 2011
    GOLD£N☆STAT£
    i was pumping diesel and the nozzle slid out of the tank i left the door open checking my engine and the trigger stayed on it landed on the floor with a strong flow aimed directly at my dashboard got a nice interior diesel wash smell stayed there for weeeeks
