Driveshaft length - 10 to 13 speed swap
Discussion in 'Freightliner Forum' started by W Bench Farms, Dec 28, 2021.
  1. W Bench Farms
    W Bench Farms Light Load Member
    211
    351
    Oct 16, 2017
    Swapping out the 10 speed in my FLD for a 13. Glad I'm doing it now, found quite a few vibration makers. Rear engine mounts, carrier bearing.
    Going to have to swap the driveshaft for a shorter one. Anyone know offhand how much shorter the 13 speed driveshaft needs to be from the 10?
  3. AModelCat
    161,251
    Measure the difference in length between the 2 transmissions. Then just take the old shaft in to a driveline shop and have them shorten it up.
  4. JoeyJunk
    JoeyJunk Road Train Member
    8,762
    68,030
    Dec 31, 2010
    Washington, PA
    Did you already have a 13? I was going to do the same in September but had other things to do first. Plus the core charge was pretty high. Guy said 10 speed cores aren't as desirable as they once were because everyone is switching to 13 and 18.
  5. W Bench Farms
    211
    351
    Oct 16, 2017
    I bought a used 13 a couple of months ago. No core on this one.
    JoeyJunk Thanks this.
  6. SmallPackage
    5,643
    18,036
    Dec 20, 2019
    Marion Texas
    The best thing to do is get the new trans bolted in and everything set and sitting normal including the suspension and then do the measurements. This way you will get the absolute best custom length to the combo and not just a ballpark.
    Every truck combo is a little different. There are 100’s of different yoke dimensions and different and odd rear collar/bearing retainer sizes too. Not every combo is uniform across the trans. models/series either. Example. I’ve got two old RTO12513’s. Both out of ‘74 Petes. Same identical “book end” and wheel base trucks. Both trans side by side look identical but one is 2-3/4 inches shorter and the yoke is a 1/2” deeper. Making swapping shafts without possible vibes questionable.
  7. wore out
    wore out Numbered Classic
    16,618
    202,598
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    broadsword and Oxbow Thank this.
