I was wondering, are there any tips or tricks to maneuvering with an extended hood truck vs a short hood, or is this something you just have to get used to? Unfortunately, I am used to trucks like Visions and Volvos, the biggest I have driven is a Mack CH, got to sit in a 379 EXHD and it scared the heck right out of me!
Also, how tight does a typical hood turn compared to say a 2001 CH, because that is what I drive and it turns terrible compared to the Visions that we now have in the fleet, and it is a short wheelbase with a setback axle, but it still takes forever to turn.
Thanks much for the help.
Driving a Hood
Discussion in 'Experienced Truckers' Advice' started by dieselpowerrules, Feb 24, 2011.
Page 1 of 3
you drive it like any other truck you've been driving...
you stop behind the vehicle in front of you so that you see that vehicles tires touching the ground.....
you make your right turns like you''re supposed to, the 'button hook" way.....
once you've driven a "hood", they are all basically the same....
"you get used to it".....
by your BIO, you've been driving for 4 years now.......you should be able to handle this.....i find it hard to believe a truck scares you.Ruthless Thanks this. -
Okay, thanks Rerun8963. I probably could handle one, but it just seems like so much more truck to get around corners compared to a baby bulldog Mack. I feel like I would have no idea as to where the steer tires are, when you come up on say a ditch thats across a street that you're swinging wide on, it disappears so much sooner than with any of the "aero" trucks I have driven.
The simple key is....be patient! (like we all should be) If you're not sure...then don't do it. If you think you need a little more space...then go wide. If cars are blocking your way...wait. And if you get stuck in a situation...reverse and try again. I've gotten stuck in a few hellish parking lots that did not have a way through just because one car that is in the worst possible spot. So I've had to get out of the parking lot and out onto the street going in reverse. Did it take forever? Yes! Did I damage the truck or any other person/vehicle? No!
Btw, I drive the aero ones too so I can't directly relate but I still say patience is the key in this business no matter what truck you're driving. GL -
Thanks Nootherids, its probably all a perception thing, but to go from a CH to a 379 to me is like going from a civic to a super duty! I have rode in almost all the hoods, but have never had the chance to drive one, and they just seem to me a totally different animal. I have a friend that is my age and has the same experience, he drove only short hoods all along, but has recently switched companies and now drives that 379 that I'm talking about. He told me that both the new companies W900 and 379 turn tighter than my CH, and they've got longer wheelbases, and I find that hard to believe, even though I know my CH turns like crap.
It just takes a couple of days of driving to get used to it. If you cannot (in a reasonable time) get the awareness of your steers and truck squared away maybe something like a classic truck is not for you. It's no different than any other truck, just need to pay attention as always.
I started on a Mack with 35* steers, terrible turning radius. Moved to a Freightshaker with 50* steers. You could turn the tires off the darn trailer with that thing. Took a couple of days to get used to the difference in visibility and styling. Not at all too hard.
Take it slow and drive it around in a parking lot a bit first to get the hang of things. -
Thanks for the reply Flying Finn, I hope what you said in the first couple of sentences isn't true, because I really like the long hoods better than the newer aero trucks in every way. The Pete 359 is my favorite truck. That new 389 with an even longer hood must be real fun to drive!
if you can get the tractor out take it to a empty parking lot and practice , also backing is going to make it a little more interesting too as the trailer will take a little more time to respond to your actions . always familiarize yourself with your equipment before taking it out on a trip .
Maybe its a good thing this CH has a bad turning radius, it will probably help me when I do finally get to drive a hood, you mention it takes the trailer longer to respond to actions with a hood, well when backing this thing it seems like when you crank the wheel to follow the trailer it takes a full minute just to be straight with the trailer again! Very slow turning...
I went from a small daycab international to a long hood 379. It only took a day or 2 for me to really get used to it. The only thing I'll say that was good about the daycab was gettin around the back country roads to hog farms in the winter. It's a ###### to get those steer tires on the long hood to get going where you want on pure ice. I never chain though so that could help probably
Page 1 of 3
