driving down mountains in truck has no engine brake,how to handle that
Discussion in 'Questions From New Drivers' started by Hova28, Sep 25, 2018.
  1. Rideandrepair
    17,430
    56,536
    Aug 8, 2015
    I used to hear 1 gear lower than you made it up in. Modern 1980 s that changed to same gear. Always wondered as mentioned about different grades up vs dn?? First time I got in big hills on 64 e of I-75. I asked an O/O who had same set up as my driveline who was also loaded heavy. He gladly showed me the fail safe way. We almost came to a stop and rolled down without a glitch nice and slow. I don’t always do that now unless I’m in a unfamiliar area. Better safe than sorry. Steady braking causes fires. Done that once. Luckily put it out!!! Live and Learn be safe. Go slow stab brake before the curve!!! Gas on it before going up the next hill so you don’t lose too much time. You’ll be a pro in no time. But go slow especially in winter.That way it won’t get away from you.Over time you’ll figure out when you can go a little faster. Don’t forget the 4 ways. Be Safe
    Oldironfan Thanks this.
  3. fargonaz
    fargonaz Road Train Member
    1,167
    4,583
    Feb 9, 2015
    Mesa, AZ
    I remember when the trolley brake stayed where you put it... yep.
    Oldironfan and Blackshack46 Thank this.
  4. homeskillet
    homeskillet Road Train Member
    6,187
    47,300
    Jun 1, 2013
    Dayton, OH
  5. 8thnote
    8thnote Road Train Member
    1,980
    3,687
    Aug 12, 2013
    Chattanooga, TN
    It depends on the length if the grade, but I would probably go down in 4th gear (assuming a 10 speed trans). That will keep you at about 18-20 mph. Also, the light steady pressure braking technique is much better than stab braking if you have no Jake brake. Just watch your brake application gauge and keep it at a nice light 15-20 psi of application pressure. You can keep it at 15-20 psi all day and your brakes will never overheat.
  6. Ridgeline
    22,607
    120,082
    What?
    You need an engine brake?
    Four years without one, I didn't worry about it, I drove as I was taught, cat mentioned it.
    Diesel Dave and Oldironfan Thank this.
  7. CK73
    CK73 Medium Load Member
    461
    602
    Dec 19, 2017
    The correct answer is, you don't. Period.
    RockinChair Thanks this.
  8. fargonaz
    1,167
    4,583
    Feb 9, 2015
    Mesa, AZ
    You have a talking cat?
  9. fargonaz
    1,167
    4,583
    Feb 9, 2015
    Mesa, AZ
    Don't what? Go down mountains?
  10. Rideandrepair
    17,430
    56,536
    Aug 8, 2015
    I’d keep the fire extinguisher handy just in case.
  11. Pumpkin Oval Head
    Pumpkin Oval Head Road Train Member
    1,679
    1,155
    Jun 24, 2010
    Scranton PA
    Start down in 5th and shift up to 6th if needed.
