driving down mountains in truck has no engine brake,how to handle that
Discussion in 'Questions From New Drivers' started by Hova28, Sep 25, 2018.
  1. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,140
    Mar 5, 2016
    White County, Arkansas
    There are thousands of combinations possible in engines, transmissions and final drive ratios combined with hundreds of tire and wheel situations possible.
    What I really like and enjoy in mountain work is a engine with a #####ing Jacobs so big and strong that every valve slamming against the piston is a big bell. If I can hear that I know I can take any load off a vertical 90 degree grade and it will ride all the way down without breathing on the brakes once.
  3. rbrtwbstr
    rbrtwbstr Road Train Member
    3,386
    7,836
    Jul 11, 2012
    in the bush somewhere
    Youll be like Wyle E Coyote chasing the Roadrunner.
    x1Heavy and Blackshack46 Thank this.
  4. MACK E-6
    49,636
    233,966
    Gentlemen, does everyone know the difference between STAB and SNUB braking??? I’m seeing the terms misused in this thread? One is an emergency measure while the other is a tried and true technique that I myself have employed bringing heavy pups across the Appalachians.
  5. rbrtwbstr
    3,386
    7,836
    Jul 11, 2012
    Stab braking is for emergencies, where you stab the brakes, locking them up, then releasing them, and repeat the process until stopped.
    Snubbing is using the brakes to slow 5 mph in three seonds, then letting off, allowing the truck to pick up 5mph, then repeating.
    RockinChair, Oxbow, IluvCATS and 2 others Thank this.
  6. MACK E-6
    49,636
    233,966
    And that’s how I always did it. Always worked, even if it did require descending 5% grades on the big road at 20-25 mph.
    Oxbow and IluvCATS Thank this.
  7. gentleroger
    gentleroger Road Train Member
    7,736
    21,032
    Jun 1, 2010
    For your knowledge you won crome accent pieces for a Cascadia bunk window.
    (I would also accept losing 500 rpms in 3 seconds.)
    IluvCATS Thanks this.
  8. rbrtwbstr
    3,386
    7,836
    Jul 11, 2012
    I've done it both ways, I really don't think one way or another is better. Doing the snub braking will never fail you when done right. I think the old way of light steady pressure is not taught anymore, probably because it is just a thing of the past.
    Now the Stab braking in an emergency, I really don't like doing it. Mostly because if I need to do that, I'm doing something wrong to begin with. We have a trailer or two that don't have ABS, and in that case, stab braking would be the better option. Hit the brakes, trailer locks up and goes sideways. Release and it straightens out. So, on non ABS trailers, it works. But these newer trailers, you just plant your foot on the pedal, and it comes to a nice straight stop. Most of the time...
    IluvCATS, gentleroger and MACK E-6 Thank this.
  9. rbrtwbstr
    3,386
    7,836
    Jul 11, 2012
    Can I just have a designated Super Trucker hat instead? Been accused of being an anger driven, maniac super trucker twice in the last 30 days now on here...:dontknow:
  10. gentleroger
    7,736
    21,032
    Jun 1, 2010
    A hat costs money and has a purpose - crome accents for a Cascadia have no value or utility.
    Today my trainee asked what a Super Trucker is, it took all my will power to not say "you are".
    rbrtwbstr Thanks this.
  11. homeskillet
    homeskillet Road Train Member
    6,187
    47,302
    Jun 1, 2013
    Dayton, OH
    That is very true.
    There are also some "old schoolers" on these boards that, after a few thousand posts, are pumping gas that destroys their credibility.
    The new guys have to learn the same way you "crusty old ########" did: by the seat of their f-----g pants.
    I learned by listening to the old hands. But even at a place with a lot of old hands still there, you might never see them.
    I've been with this carrier 5 months. I've met the TM, 2 mechanics out of 5, and 2 drivers out of 22.
    Back when I first started in the 90s, I met all the drivers at my terminal the first month. We had time to sit and talk, compare notes, learn new approaches to problems. It ain't like that anymore. Probably never will be again.
    Trucking "still sucks less than anything else I'm qualified to do".
