Driving technique (need help here)
Discussion in 'Experienced Truckers' Advice' started by TripleSix, Jan 29, 2014.
  1. TripleSix
    129,611
    Went running down I75 to 59. Weather was bad. Hit the 459 loop and all hell broke loose. 4 wheelers do their typical 4wheeler thing where they put their hazards on and ride side by side in cluster (military perspective, it would be like sending a 16th century army standing shoulder to shoulder to D DAY.)
    For the most part, trucks were fine. A half million cars went on field trips. 1 truck. Excellent work, gang. Now here's where the trucks fail. There are sections of 459 that are hilly. Traffic is slowing down, 4s and big trucks are staring to spin out going up a grade. The 4wheeler MO is to stand on the throttle. And they go on a field trip. Traffic is slowing rapidly. My drives started to spin. What do you do when your drives start to spin?
    This is the part I need help with. There's a certain technique to regaining traction, even while going uphill. I need someone to explain it better than me. I did not lock anything in. I can, but it's not necessary if you do it right. As soon as I felt the drives spin, I geared down, slight throttle, gear down, slight throttle, gear down. She regained traction and I went right up the hill of ice. Got to the 65 junction and there's another long grade. Drives started spinning and I did it again and she went right up the hill.
    Road got shut down and I decided to exit (what's the point of eating up your hours and you're not moving anywhere?). Started gearing down, stop sign at the top...crawling, made the turn and got into the truckstop. Pulled the yellow knob, SAFE! I hear drivers on the radio spinning out. They're chaining up in the middle of the interstate. Heard a hand on the radio tell a driver about gearing down and the truck walking right up the hill without chains. Finally! A trucker.
    Anyways, I decided to start a thread to try to help the people who haven't done a lot of winter driving, how and when to use the power divider, lockers...etc. Input requested.
  3. Krashdragon
    Krashdragon Medium Load Member
    651
    305
    Apr 10, 2012
    Cleburne, Tx
    Ok, so if I,m poking along slowly in say..5th gear ..25mph for my truck... I just keep gearing down and feathering the throttle until the tires grab?
    Thanks
    Mary
    Dinomite and Lepton1 Thank this.
  4. Wooly Rhino
    Wooly Rhino Road Train Member
    3,367
    5,648
    Jul 6, 2008
    Liberty, Missouri
    I may not be understanding so feel free to straighten me out but, when your wheels spin you are out of control. Backing off the throttle is the first thing to do. Gearing down would put more power to your drives and I would think that would be the wrong thing to do. Now if you are saying that you wheels have found traction then downshifting would increase the rolling friction and that would be correct as braking would cause you to slide again. You would be working as an anti lock brake in essence.
    You can control the wheels only so long as they are freely turning. Sliding friction is way less then rolling friction.
    chicknwing, Dinomite and Lepton1 Thank this.
  5. Lepton1
    Lepton1 Road Train Member
    12,647
    25,588
    Nov 23, 2012
    Yukon, OK
    TripleSix, that pretty well sums up my thinking about handling a slippery grade. Feather the throttle and downshift as needed. A heavy throttle will break traction.
    blairandgretchen Thanks this.
  6. TripleSix
    129,611
    See, that's the tricky part I can't explain. I run the minimum speed limit, which in Alabama was 40mph. You don't want to stop. If you stop on a grade, you're toast. You will sit right there til either the ice melts or a wrecker can get you.
    I have an 18 speed. I was rolling 40 mph in 17th gear which is low rpm. Hit a hill, carry momentum, drop a gear, easy on the throttle, wheel slip drop gear, easy on the throttle until you find that gear where the wheels don't slip, low rpm, NO SPIN, walk right up the hill. I didn't feather, just kept my rpms lower than 1200 and almost idle up the grades. Even long grades.
    I know how to do it, I just need someone else to explain better. Anyone have a truck with a 9,10 or an automatic, open diff rig that can explain their technique.
  7. rbrtwbstr
    rbrtwbstr Road Train Member
    3,374
    7,783
    Jul 11, 2012
    in the bush somewhere
    I usually stay in a higher gear and lug the engine a little. By lugging it, you aren't sending as much power to the drives. And if I do start to spin, I let off the throttle completely and idle until I regain traction, then gradually increase throttle. I might be doing it all wrong, but it always seems to work. Anybody's thoughts?
    Criminey Jade and TripleSix Thank this.
  8. TripleSix
    129,611
    Doing it all wrong is spinning out.
  9. chicknwing
    chicknwing Medium Load Member
    526
    601
    Jan 4, 2014
    Charlotte, NC
    I have always had luck with just getting off the throttle and allowing the torque to pull the truck on its own. Kind of like when you wheel hop in the sand, just let the gears do all the work, no fuel required. Perhaps since you were in 17th and already had low rpm's I would have downshifted to a lower gear and then allowed the truck to do its thing, once I had traction I would feather the throttle to get more rolling traction....
  10. 379exhd
    379exhd Road Train Member
    2,925
    3,153
    Jun 25, 2012
    rolling through hell
    9/10 is a little trickier than our 18spds. Back when my dad ran a truck with a 10spd in then winter he kept the revs up on the high end instead of the low end because of the RPM drop. He always told me to stay out of the torque and keep it in the horse power light foot barely use the throttle. There's a bigger gap between gears least there was on his 400 rpm or so so when it lugged down he ended up right where he didn't want to be which was in the torque. And the volvos he drove had traction control. Soooooo when you lost traction you lost total engine power and created a cluster of a situation for yourself and everybody behind you. So he used horsepower and high RPMS when he was running the winter and going up and down the hills. That's the way I've always done it even with my 18. Even what you were doing triplesix lugging and low rpm was the same concept. Staying OUT of the torque. Torque falls off below 1200rpm very rapidly with the newer motors. Torque falls off about about 1500rpm very rapidly with today's motors.
    Its about staying out of the torque many think you have to have a heavy foot to pull a hill. When in reality you can have a very light foot and be in a low gear at a higher rpm and pull the hill. Or have a light foot lug it up in a higher gear either way works.
    I've always locked my power divider to climb hills in the winter before I started up them if it was slick dropped a couple gears and pulled the hill above 1800rpm with a light foot. Dropping as many as necessary to keep wheel spin to a minimum. Its always worked for me but this way seems like it would work just as well I'd be a little more concerned getting up around that 1200 mark getting on it a little too hard depending on your gears and how touchy your throttle is.
    And watch your boost gauge that also helps to determine how heavy your foot is on the throttle I usually let off when I hear the turbo start to spool up, and the needle start to rise. Don't know if that's a good way to do it or not but its always worked so far. Having put one in the ditch or watched my trailer try and push my tractor around yet knock on wood.
    Good discussion though have to follow it and see where it goes.
    Hammer166 and blairandgretchen Thank this.
  11. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    Breaking traction = lost control. Keep your rpms low as possible in the peak torque range. Example an ISX peak torque is at 1200 rpms. Put the engine to work and run 1200 rpms. If you continue to spin it's time to consider pulling over.
    I'm curious where were you headed to select hilly I-459 in a snow storm? Why didn't you run straight through town? I know they have restrictions but B-ham never enforces it with a truck stop downtown. Under them circumstances I would of ran straight through.
