Dropping a Drive Shaft in a 2010 Freightliner
Discussion in 'Ask An Owner Operator' started by haler1227, Feb 11, 2015.
  1. haler1227
    haler1227 Bobtail Member
    4
    I was hauling a heavy container and all of a sudden heard a pop and the truck stopped. I got out to see that the drive shaft broke. What would cause the drive shaft to break?
  3. Skate-Board
    Skate-Board Road Train Member
    3,801
    3,995
    Aug 9, 2014
    Merrimack, NH
    They do break once in a while. One thing that can cause damage is being stuck in snow or sand and getting the rear end to start jumping up and down.
  4. sdaniel
    sdaniel Road Train Member
    5,511
    4,420
    Sep 7, 2011
    Pelham N.C.
    All that power under the hood ???
    RedForeman and Cetane+ Thank this.
  5. bad-luck
    bad-luck Road Train Member
    3,260
    5,980
    Nov 16, 2013
    Baltimore, Maryland
    Was the actual drive shaft broken? Or was it a u-joint?
  6. codyschmidt
    codyschmidt Light Load Member
    120
    108
    Jan 25, 2011
    landrum,sc
    T h e h e a v y c o n t a i n er !!!
    RedForeman Thanks this.
  7. wore out
    wore out Numbered Classic
    15,457
    186,620
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    I have seen the weld between the tube and flange not have good penetration on one side and cause it. Course everything else mentioned too
  8. cabwrecker
    cabwrecker The clutch wrecker
    1,626
    1,423
    Mar 23, 2012
    You laugh but no one is laughing when that DD is putting power to the ground longer than a cummins or cat...even if it is only 25 hp...
  9. KenworthGuyNH
    KenworthGuyNH Road Train Member
    1,050
    2,686
    Dec 11, 2011
    Central, NH
    Your info. is a little thin to give an internet diagnosis of your driveshaft failure!!! How about some details......
  10. 30-aught-6
    30-aught-6 Light Load Member
    155
    128
    Dec 16, 2014
    U did say u were hauling a HEAVY CONTAINER right?:biggrin_25513:
  11. TripleSix
    128,181
    Has to be a u joint or the yoke. A driveshaft will twist before it breaks.
    Several causes.
    1. Dumping the clutch on takeoff
    2. Too high a gear on takeoff, which will require you to rev the motor and dump the clutch to avoid stalling the engine.
    3. U joint or yoke failure caused by a lack of lube/grease. In other words, your PM services need to be more frequent.
    4. Normal wear.
