I've been told that it's not a good idea to haul a floor load of potatoes in a dry van, but does that also apply this time of year when it's cool(er)?
I also have a translucent top; would I be rejected for this?
It's posted at $1.49/mile from TX to NC, picking up on 12/26. The only reason I'm even considering it is because I'm thinking that's a super lowball rate and I should be able to negotiate it up quite a bit. And it's going 90 miles from where I want to be in NC. But I'm not sure it would be worth the hassle even at $2.50 / mile.
Thoughts?
Dry van floor load potatoes
Discussion in 'Ask An Owner Operator' started by windsmith, Dec 23, 2012.
Page 1 of 4
contact them and see if your trailer will work. They will tell you what you need.
Might require a heater--BUT--That is an ridiculously LOW RATE for chip stock--should be much closer to $2.50--and that is running very legal--actually I am basing it on 45 bags in wagon--with a dry box like that you should be able to scale 48 bags if not more....
windsmith and VisionLogistics Thank this. -
They may want you to have produce vents (greater than 100 sq In) in the trailer too.
The issue with floor load is they either dump you off or you are "washed" off with water. Washed off I would not want done in my trailer as I have a wood floor and wood walls.
I just hauled a load of squash in my van recently and doubt I will do it again anytime soon. Fully enclosed, the van was dripping with moisture when I opened it up. I couldn't vent it either while driving as it was mid-30's when I hauled them.Last edited: Dec 23, 2012
windsmith Thanks this. -
Aside from cheap, which you already know, plan on a real washout when you're done. They usually take those off with a front end loader. You'll have potato shrapnel in every nook and cranny. Low ambient temps may be a problem as well.
CondoCruiser, windsmith and VisionLogistics Thank this. -
The potatoes husband has hauled in reefer are a mess and the trailer has to be washed out. They are just dumped in and they get in all the rails etc. I don't even know if he has ever hauled too many bagged or boxed in some way.
The temp would have to be warm enough to keep them from freezing also.VisionLogistics Thanks this. -
Taters don't pay much....period !
They also water floated out pears for Gerber on one load he had. Very interesting process for getting things done. -
I hauled a couple loads in my van. It took two GOOD washouts and then it's still wasn't 100 percent. Mine were loaded from a belt and dumped with a lift. I was getting paid good as both loads were Frito Lay, but in the end it wasn't worth the mess and smell. If you have a composite interior, it would be better.
Page 1 of 4
