DSP 40 and DS404
Discussion in 'Experienced Truckers' Advice' started by flat-step, Mar 29, 2015.
  1. flat-step
    flat-step Light Load Member
    96
    21
    May 11, 2011
    Hello All,
    I have truck with DS404 3:70 rear diff which needs to be replaced in the near future. I also have a truck which i took off the road last year with 6 month old DSP40 4:11 diff. Can i swap them? and if yes what else do i need from the donor truck to make it work. Thank you
  3. 1johnb
    1johnb Medium Load Member
    542
    405
    Jun 13, 2012
    New Paris Ohio
    They will interchange but you have to do both because of the ratio difference. A DS40 & DS404 have the same bolt pattern and diameter.
    Motor Trucking Thanks this.
