Dt466e transmission changeover help!
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Moss7774, Jan 16, 2019.
  1. Moss7774
    Moss7774 Bobtail Member
    Can anyone help me with a setup. I have a 1999 International Dt466e rollback. It had the spicer 6speed manual transmission. I decided to change it over to the Allison automatic. I didnt do alot of research before hand and now im stuck. I bought everything to change it to the Allison At545(bad move). After trying two different transmissions my top speed is only 55mph at 2500rpm’s and barely pulls a hill unloaded. I checked and the truck has 3.42 rear end in it. And also im running 19.5 wheels. I also will have to use a mechanical park brake since my rollback doesn’t have air brakes. Should i try the mt643? Any help would be greatly appreciated.
  3. ClineER
    ClineER Light Load Member
    229
    139
    Apr 27, 2016
    N.E. Oklahoma
    Was the old manual trans an od od direct top gear. Sounds like trans isnt hitting 4th gear. I would verify shifter positions, and throttle kickdown. Otherwise there is a problem with trans.
    The 545 is commen behind the 466 so should be fine for a rollback
