DT466E with disappearing oil
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by 704mover, Apr 23, 2021.
  1. 704mover
    704mover Light Load Member
    60
    22
    Mar 8, 2018
    2003 International 4700 dt466e. On a 2 hour trip yesterday the low oil pressure warning went off. I immediately pulled over and shut it down. No oil on stick! I had checked it that morning and was fine. After putting 4 gallons of oil back in it I was on my way. Another 30 minutes home and it was already a gallon low again. It's running perfect, and no smoke. The coolant is clean with no oil. Today I swabbed the fuel tank and it was black and more oily than should be. Also 6 months ago, we had a serious oil leak down the drivers side of the block and I pulled the high pressure fuel manifold and replaced the gasket. That fixed my oil leak and I had forgotten about it till today, but could my disappearing oil be getting into my fuel through an internal leak behind that manifold or is there something else to check that maybe common on this engine? I'm assuming it could be injector o rings also? But like I said it's running great as usual no smoke. Help or ideas appreciated. Thanks
  3. Hulld
    Hulld Road Train Member
    2,883
    6,566
    Oct 19, 2015
    Upstate NY
    @Heavyd could probably answer that question.
    704mover Thanks this.
  4. AModelCat
    158,774
    @Flint1 might have some input as well.
    I'm not overly familiar with the DT engines but I believe they are a HEUI fuel injection system. I'm thinking the fuel injection pump is culprit and allowing pressurized oil to enter the fuel system.
  5. wore out
    wore out Numbered Classic
    15,884
    192,142
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Look in your fuel tanks, injector o rings can do this. Most likely you’ll find they were not torqued, have been working up and down.
  6. 704mover
    60
    22
    Mar 8, 2018
    Yes, I'm definitely figuring that it's
  7. Goodysnap
    Goodysnap Road Train Member
    3,716
    9,022
    Jul 12, 2017
    HEUI injectors. By your description you indeed have engine oil returning to the fuel tank. I would agree you have an injector/o-ring split. Been a while since I worked on this engine.
  8. 704mover
    60
    22
    Mar 8, 2018
    Look in my tanks for what? I already said there was oil in the tanks. No injector replacement recently. We I framed this truck around 125,000 miles ago.
  9. wore out
    15,884
    192,142
    Jun 5, 2013
  10. ChuckMartel
    ChuckMartel Light Load Member
    160
    94
    Jan 22, 2021
    Order some o ring kits and start pulling injectors.
    704mover and jamespmack Thank this.
  11. Flint1
    Flint1 Road Train Member
    1,143
    9,805
    Sep 4, 2019
    Alberta
    I would agree injector o rings will cause this as others have stated.
    @wore out is an extremely knowledgeable hand. A thank you probably would have sufficed...
    beastr123, Goodysnap, p608 and 2 others Thank this.
