I have a 2001 DT66 that will not start we have changed high pressure oil pump, cam sensor, oil pressure sensor, swap ed ecm, sensor on the fuel rail and it still wont start now we are pulling injectors looking for oil leaks. Any ideas that could help me?
DT66
Discussion in 'International Forum' started by adamd2012, Oct 21, 2013.
Ok, first we need to know if the ECM is properly booting up at key on. At key on you should get the yellow "Warn engine" light and/or the red "Stop engine" light coming on for a bulb check. The ECM turns these lights on. No lights means the ECM is not getting power. Another check for the ECM is to watch the tach while cranking. If the tach shows some rpm during cranking this means the ECM is getting power and the cam sensor is also reading properly. Are you sure the engine is getting enough fuel?
No we are not we are not getting any fuel. I will look into what you just told me
We turned it over the tack is moving oil pressure goes up also
Run a test fuel line from the inlet of filter to the tank, reprime and see if starts. Does this engine have a hand primer on it? If it does, you should be able to pump enough fuel up to the head with that. You have to vigorously pump it while cranking to get the engine started. If it still does not start you have a restriction on the inlet side or sucking all air. If it will start while pumping the hand primer, but dies once you stop I would say the fuel pump is gone.
