DUAL TIRE PRESSURE EQUALIZATION MONITORING SYSTEM
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Coolbreezin, Apr 6, 2017.
  1. barroll
    barroll Road Train Member
    1,096
    544
    Nov 23, 2010
    Southwest Michigan
    I've tried the crossfire and cat's eye. Really prefer the cat's eye because an elbow on the crossfire set I had cracked along a seam, then didn't register that it let all but 30psi out of the inside dual. The tire had air when I kicked it in the morning, and the crossfire showed about 100psi cold, then I did 650 miles under a load of onions in the middle of summer through the desert at 70mph, and when I shut down the tire that had 22/32" of tread on it that morning was so badly cupped I couldn't trust it anymore. Crossfire still read 115psi until I pulled it off because the soapy water test showed nothing but foam down the casting seam on the inside elbow. Never had a problem with cat's eye.
    mhyn Thanks this.
