Dual vs. single exhaust:
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Powell-Peralta, Apr 28, 2011.
  1. Powell-Peralta
    Powell-Peralta Road Train Member
    1,585
    240
    Jul 17, 2007
    Is dual exhaust quieter than single?
  3. melpromud
    melpromud Medium Load Member
    463
    114
    Jan 29, 2010
    camden ny
    I dont think so. I think duels are just for looks anymore.
  4. Nitropickup
    Nitropickup Bobtail Member
    42
    7
    Apr 18, 2011
    Houston, TX
    There are soooo many variables that it's hard to generalize, but... In general a more restrictive exhaust in quieter and singles are in general more restrictive then duals. However duals can be easily made quieter without restriction and singles can be made less restrictive without adding noise.
    In motion, through a pipe, all the laws of hydrodynamics also apply to gasses.
  5. Donk
    Donk Have a Cup Of Concrete
    1,643
    9,232
    Apr 27, 2008
    Duals are useful where higher HP applications do not allow sufficent flow through quiet mufflers, so by adding two, flow is retained and noise kept down.
    in the real world, two pipes look better, but when the system rots out, cost more to replace.
    i have an ISX with twin stacks, and on a hard pull it heats up the pipes AND MUFFLERS enough to change the color of the steel. my mufflers are straight through units also.
  6. Krooser
    Krooser Road Train Member
    2,493
    1,066
    Jul 25, 2010
    Wisconsin
    The point of the biggest restriction will determine the ultimate flow of the exhaust... if you have two manifolds/split manifolds (one for each stack) duals make more power. But since you only have one pipe running from the engine a single exhaust will make as much power as duals.
    When inline diesels engines are put on an engine dyno they have a single exhaust... duals would do nothing to improve the HP...
    Let the beatings begin...
    Runnin Thanks this.
  7. Jfaulk99
    Jfaulk99 Road Train Member
    2,914
    1,652
    May 16, 2009
    Couch
    I believe when the Acert first came out you couldn't order a truck with a single exhaust, the factory converters wouldn't flow enough. Only lasted like a year then they made larger converters. Didn't matter though most didn't stay on the trucks very long. You'd think they would build these trucks better, I know mine barely made it home from the dealer before those pesky things fell off.:biggrin_2559:
    For me it's dual all the way. Got one truck with a single stack and a single external air cleaner (w900) and it annoys me. Both are on the passenger side and it looks funny.
    07-379Pete Thanks this.
  8. Licensed to kill
    Licensed to kill Heavy Load Member
    830
    2,434
    Dec 31, 2010
    Alberta
    While what you claim is true, the problem with your hypothesis is that "the point of the biggest restriction" is the muffler and that occurs AFTER the Y in a dual application therefore the engine will only experience half of the restriction in a dual system.
  9. Flying Dutchman
    Flying Dutchman Road Train Member
    1,274
    522
    Nov 2, 2009
    Northern California
    In the cab, I have heard many drivers (for older trucks) say duals were louder.
  10. Krooser
    2,493
    1,066
    Jul 25, 2010
    Wisconsin
    Converters are a whole different ball game...
    If single exhaust won't allow a free enough flow why don't they derate the HP ratings on trucks with single stacks? Say it's 500 HP with twins but only 485 with a single exhaust? The answer is the duals don't make more HP... so the the HP rating stays the same.
    You can get a single muffler that flows more than 2500 CFM... that's a lot of air. Straight pipes will flow even more...
