Dumbest question you've heard...draining air tanks?
Discussion in 'Questions From New Drivers' started by emaja, Feb 27, 2016.
  1. emaja
    emaja Bobtail Member
    5
    Sep 1, 2015
    I was too embarrassed to ask at the shop but where is the drain cord on a 2014 Freighliner Cascadia?
    taxihacker66 Thanks this.
  3. akfisher
    akfisher Road Train Member
    1,023
    950
    Apr 23, 2015
    Well gotta be there. Might just be a gate valve.
  4. ZVar
    ZVar Road Train Member
    10,911
    23,828
    Sep 10, 2010
    Flint, MI
    If its not by the fuel cap it may not have one. Just look along the frame on both sides and ask the shop if you can't find it. Just be honest and you won't look like a fool. Go in asking like this: "I've looked all over the place and cannot find the air tank drains. Am I blind or is there not a drain I can reach?" That way you come off as wanting to learn instead of comming off as an idiot.
    -Steven
    JReding, Bean Jr. and Bob Dobalina Thank this.
  5. tucker
    tucker Road Train Member
    12,647
    40,423
    Jun 13, 2008
    IN
    In 6 months I never found mine, though I only looked once and not for long
  6. dca
    dca Road Train Member
    6,834
    11,427
    May 31, 2011
    Earth
    there's a panel on the top step on the driver's side. open it and reach in.. feel for a thin cable.. all are usualy on the driver's side. pull on the cable
    okiedokie Thanks this.
  7. skellr
    skellr Road Train Member
    8,737
    12,187
    Jul 17, 2011
    The Village, Portmeirion
    There are usually two cable pulls near the battery box and two near the frame rail near the rear steps.
    crxdc Thanks this.
  8. mangdriver
    mangdriver Light Load Member
    61
    57
    Feb 13, 2016
    I did that recently, I asked a more experianced driver, and he wasn't sure either, asked another he should me where it was on his (these are all the same military tractors). I went to mine, and it didn't have the cord any more, wrote it up for the shop.
  9. uncleal13
    uncleal13 Road Train Member
    3,797
    6,295
    Apr 9, 2009
    Humboldt, Sk
    Roll around on the ground, get under neath, look at the bottom of the tanks, the pull cords will end there. Then follow them up to where the pull lanyards are located.
    Lepton1, 59MackB61, JReding and 5 others Thank this.
  10. emaja
    5
    Sep 1, 2015
    Not under the panel where the DEF goes. I did find one near the frame rail by the back steps though. I'll look under in the morning.
    I'm new - only two weeks solo and boy am I getting a rude awakening. This is an amazing and challenging job.
  11. Starboyjim
    Starboyjim Road Train Member
    2,039
    1,424
    Dec 10, 2011
    Weed, CA
    Crawl under there, you'll see air tanks. I'm sure it's a real challenge running a semi truck without some.
    Nothing online? Freightliner help link?
