I have a kenworth t680. The other day i dumped the air in my bags from a dump switch in the cab. When i hit the switch again the airbags never reinflated. So i pulled the dump line from the leveling valve and it had air to it and while it was off the bags once again inflated. So probably a bad dump valve or switch? Anyway to just plug off the dump air line or bypass the dump valve long enough to get it home?
Dump switch gone bad? Can I plug the line off to get home?
Discussion in 'Ask An Owner Operator' started by Eric sly, Dec 21, 2021.
Is it possible you have some water in the air system and it got cold enough to freeze in the leveling valve?
beastr123 and Buckeyes614 Thank this. -
When cold out don't deflate 100% once load breaks inflate
Dave1837, ProfessionalNoticer, Oxbow and 2 others Thank this.
What what??.
EOA solenoid probably stuck open.
jamespmack and Oxbow Thank this.
