Dump trailers
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by dirttrackking55, Nov 20, 2016.
  1. dirttrackking55
    dirttrackking55 Bobtail Member
    41
    6
    Dec 17, 2011
    Georgia
    How does it work with dump trailers I know a 40ft trailer you can haul 80000 lbs but my question is can you still haul 80000 with a trailer that is 35ft and less as long as it is a trI axle? or how does all that work. I live in GA if it matters
  3. Blackshack46
    Blackshack46 Road Train Member
    What does the placard say it's rated for on the trailer? A combination tractor trailer, should be able to max your gvw at 80,000. But, what does the placard say for gross and axle weights?
    dirttrackking55 Thanks this.
  4. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,130
    Mar 5, 2016
    White County, Arkansas
    STONE. that is what matters. You don't need much to gross out. Now if you volume out Stone in a big trailer it's going over gross weight. Now you probably can volume fill it with sand and probably keep your gross at 80000.
    Most of the trailer dumps for stone service is short. They don't need much. I see it as a advantage over standard dumps. Other than those who carry 5 axles, three drives and two tags under a extra large dump bed in addition to the steer up front. That's 6 axles. Should be pretty good for close to 70K ...
  5. poppapump1332
    poppapump1332 Road Train Member
    2,987
    2,465
    Jan 2, 2010
    birdsboro,pa
    Nope almost all trailers pulling stone out of quarries around here in pa anyway are 39ft frameless.
    dirttrackking55 and x1Heavy Thank this.
  6. str8t10
    str8t10 Medium Load Member
    323
    415
    Apr 25, 2015
    Rochester,ny
    The company I work for does stone most of the yr. We run 36ft tri-axle plus a tag axle. We're allowed 39 ton in the box. 117k total gross but we only run local in western ny. YMMV
  7. Ruthless
    Ruthless Road Train Member
    8,810
    86,343
    Aug 28, 2010
    The City.
    Bc that's the base for otr specs. Any Shorter and some states won't give you full weight rating because of bridge law. So if you run a 24' lets say, it may well work fine for whatever locale you're in: but if you want to sell it to get something different the market is very small to sell that type of equipment..
    That being said, having 15' more wagon to put up in the air doesn't sound ideal to me. But wtf do I know: I'm not a legislator
    Grubby, wore out, SL3406 and 1 other person Thank this.
  8. wore out
    wore out Numbered Classic
    15,388
    185,797
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Sure gets dicey on a windy day with that much up in the air. Make sure it's frameless less likely to take the whole truck when it flops. It ain't but when if you pull it long enough
    Grubby, Ruthless and dirttrackking55 Thank this.
  9. x1Heavy
    34,017
    42,130
    Mar 5, 2016
    I was recalling the 20 foot TEU container boxes loaded beyond 80K having to nurse it around the 35 mph curve south of York PA northbound on I-81. The #### thing will just about tip at 25 if you let it. I know in my hearts of hearts that 5 axle set up don't mean a #### thing except that 99K permit for grossweight in the side box but nothing for PA.
    I hated chivviying those little trailers around. such a chore. If you really wanna be made to look like a dummy know nothing, get a tractor with a wheel base longer than that 20 footer. See if you can ever back it in....
  10. poppapump1332
    2,987
    2,465
    Jan 2, 2010
    birdsboro,pa
    Dumping a frameless of stone is a cake walk now dumping a frameless of ash in the landfill can be nerve wrecking at times.we've had guys quit cause of being scared of dumping in the landfill .As far as short trailers first I'd rather have it spread out in a 39ft trailer not as high and top heavy.Second when you haul stone you usually haul something back like sand/ash/salt etc so a short trailer just isn't practical.
    x1Heavy, wore out and dirttrackking55 Thank this.
  11. johndeere4020
    8,522
    119,291
    Jan 1, 2010
    Sand is heavier than stone you fill a trailer with sand it will be heavier than stone filled to the same volume.
