Dump Truck Bounce/Hopping
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by josephbolda, Jul 2, 2020.
  1. josephbolda
    josephbolda Bobtail Member
    5
    97 International dump truck is bouncing/hopping. Not like the death wobble. Steering wheel doesn't move but the truck bounces even on flat surface. Thought maybe it was the tires so put 10 brand new tires on and it made the bounce WORSE!!! Had front end checked out and it was all good. Good tire rods, kingpins, leak springs, brakes were good. It bounces consistently through all speeds when before it was only at 45-50+ mph. Tried putting it in neutral going 45-50 and still bounced. Alignment was done as well. Taking it back to tire guy on monday to make sure tires were properly balanced and mounted. The cab is leaning to the left a good 3-4 inches. Could the cab mounts cause bouncing after all new tires installed and cause worse bouncing? I need suggestions please. Thank you!
  3. Caterpillar Cowboy
    Caterpillar Cowboy Heavy Load Member
    837
    607
    Nov 11, 2010
    Wyoming
    Bouncy? Sounds like a dump truck to me!
    Badmon Thanks this.
  4. Dino soar
    Dino soar Road Train Member
    4,809
    26,922
    Dec 8, 2017
    So many questions...
    Is this a new to you truck? Did this suddenly happen or just get worse over time? Is it the back-end or front-end or more on one side...
    If a truck has a shorter wheelbase like a 15 foot bed or something like that with a Hendrickson suspension that truck will bounce you around all over the place empty. Longer wheelbase is like 17 1/2 or longer beds do better. Loaded rides nice.
    There are a lot of reasons a truck can feel like it bounces. Try to be as specific as you can and maybe someone can help you.
  5. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    Pay to have all tires bal. that should make a big diff. in the ride?
  6. bad-luck
    bad-luck Road Train Member
    3,376
    6,248
    Nov 16, 2013
    Baltimore, Maryland
    Cab bushings would make the cab lean.
  7. josephbolda
    5
    I’ve had the truck over 3 years and it slowly got worse over time. Took a couple buddies for a ride, some say bounce some say wobble. We can’t seem to figure out where it’s coming from. Front end was checked and good. The bed is 18ft so longer wheelbase. When it’s loaded it is 100X worse! Now in 5th gear it bounces more when before it’ll only do it 7th plus. Thank you everyone for your responses!
  8. Dino soar
    4,809
    26,922
    Dec 8, 2017
    Have you checked your U-joints wheel bearings and universals and pinions?
    If they are spoke wheels are you sure everything is true? If not inexpensive tires can be out of Round right from the factory.
    Truemac, speedyk and BoxCarKidd Thank this.
  9. Lowboy456
    Lowboy456 Light Load Member
    278
    128
    Mar 14, 2017
    We have a 96 Pete 357 that does the same thing and Im guessing that if both sets of wheels were off the ground to where it could be run up to 45 MPH there would be a hole lot of shaking going on because of unbalanced tires.
  10. NightWind
    NightWind Road Train Member
    2,714
    19,164
    Nov 11, 2006
    Sunny South, AL
    I'd check the shocks which a lot of people don't understand is actually what keeps the tires on the pavement.
    I'd also balance every tire on the truck.
    speedyk Thanks this.
  11. AModelCat
    161,606
    I'd like to know what suspension is in the truck. Could be very usefully in the diagnosis.
    Caterpillar Cowboy and NightWind Thank this.
