Dump truck hyd..help
Discussion in 'Trucks [ Eighteen Wheelers ]' started by earthmover, Nov 15, 2015.
  1. earthmover
    earthmover Medium Load Member
    563
    20
    Jan 27, 2009
    castalia , north carolina
    Ok guys I get a call from my driver I left the bed take me hand off the lever and the bed comes down with out moving it to download position. ..I got check the truck thinking fluid is low or something nope fluid is good but bed easy back down everytime you left it ..I'm thinking the control inside the truck is bad but not sure ..it's 200 a lone but hate to buy it and it's not the problem. .anyone have any idea on what could be going on ..thanks
  3. wore out
    wore out Numbered Classic
    15,884
    192,117
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Make sure the valve on the pump is going to full lift position
  4. BayouBlue
    BayouBlue Light Load Member
    52
    14
    Oct 29, 2015
    Kennesaw, GA
    the hydraulic valve spool centering springs may be worn out and the valve is falling slightly into the down position. Otherwise, bad cylinder seals will allow to drop slowly. Listen to hear if valve is diverting fluid to cylinder down position. If you put up and shut everything down, you will be able to hear where the fluid is flowing.
  5. 4x4_Welder
    4x4_Welder Medium Load Member
    300
    213
    Sep 16, 2014
    Eastern Orygun
    Is it a single or double acting cylinder? If it's a single acting and not gushing fluid then it has to be a valve issue, if it's a double it could be bypassing fluid past the piston.
    lester Thanks this.
  6. earthmover
    563
    20
    Jan 27, 2009
    It's a single and no fluid coming out anywhere. .I had the cylinder repacked last year around this time..also when it goes up in notice the hose jumps a little like it's no fluid or something. .guess it's time for a new pump..any idea of the price of this things ..
  7. earthmover
    563
    20
    Jan 27, 2009
  8. earthmover
    563
    20
    Jan 27, 2009
    Call the place that repack the cylinder was to that sounds like it's full of air..and needs to be bleed..so I'll try that tomorrow to late and dark tonight. .thanks guys I'll post back on what the problem is..
  9. earthmover
    563
    20
    Jan 27, 2009
    Yeah it's pushing the fluid back in the tank like it's in the down position
  10. earthmover
    563
    20
    Jan 27, 2009
    Guess I'm going to have to replace the pump...I took the controls line off and use my air compressor to left the bed and it still comes down so I know the controls are working the way they supposed to
  11. BayouBlue
    52
    14
    Oct 29, 2015
    Kennesaw, GA
    Unfortunately earthmover, most companies do not, or will not sell the springs. You may find some at a hydraulic shop that rebuilds valves, if a solenoid is placed on the same valve, they will have the extra laying around, probably in mechanics tool box.
